Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 01-23-2012, 08:17 PM
crazycooter
Default No sound from Speakers. Have codes. Help!
Hello, I am new here. I bought a 2006 Dodge Ram 3500 Diesel. Now the radio seems to work fine but no sound from speakers.
There is an active codes:
U0186 (lost communication with audio amplifier)
B140B (rear left audio speaker output circuit open)
B1403 (front left audio speaker output circuit open)
B140F (rear right audio speaker output circuit open)
B1407 (front right audio speaker output circuit open)
All fuses under hood apear to be ok. Also when I try to put a CD in the head unit it spits it back out and displays "error".
Any help would be great!!!!!!
Is the head unit shot? Amp shot? Fuse that I don't know about blown?.....
Thank you!
Old 01-23-2012, 08:38 PM
Scoooter's Avatar
Scoooter Scoooter is offline
Vehicle: 2009 Dodge Ram 1500
Scoooter is on a distinguished road
Man I don't think anyone can know that till it's torn apart. One failure could be causing it to throw another. I would guess the amp but I'm not sure why the head unit would spit out the CD. Something could have happened that fried both. There just isn't anyway for us to know for sure without taking it apart.
www.AllCyclesGroup.com
Old 01-23-2012, 10:38 PM
crazycooter
Thanks for the reply!
I don't really care about the CD problem as I don't listen to them but I mentioned it in case it is related.
I am not really sure where to start on this problem....I hate electrical issues!
Old 01-23-2012, 10:50 PM
Scoooter's Avatar
Best thing is to take it to a stereo shop. Kicking out the CD could mean a head unit issue or your putting in a CD that's not an audio CD. There is just no way to know for sure without hands on. If someone else knows please chime in.
Old 01-24-2012, 03:47 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Start by checking/replacing Fuse 36 (25A). If that's OK, then check the wiring connectors on the amplifier unit which is located behind the glove box. Take special note of the Black 22 pin connector.
brad
Interested in one of my mods?
Old 01-24-2012, 09:55 PM
crazycooter
Thanks.
Fuse 36 is good, wiring connections to amp are good.
What now? I hope I don't have to take it to Dodge for this problem.
Anybody else have any ideas???
Thanks!
Old 01-24-2012, 11:00 PM
brad12kx's Avatar
Rep:2581
My instinct tells me the amplifier is in trouble. But before you spend a bunch of hard earned $ on a new one, we should check a few things to verify that the power is actually getting to the amp.
Do you have the 'Infinity' sound system?
brad
Old 07-04-2014, 06:39 PM
max240p max240p is offline
Vehicle: 2010
Trim Level: HZ
max240p is on a distinguished road
Same problem with rear front speaker. Btw where is the fuse 36?
