Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 01-13-2012, 06:36 PM
93vando 93vando is offline
Vehicle: 1993 Ram Van 150
Color: wht
Engine: 1994-2001 239ci (3.9L) Magnum V6 175hp
93vando is on a distinguished road
Default 93 Ram Van 150 Transmission
My tran leaks from the front seal when it is running. If I fill to correct level the shifting is smooth and at the right rpms. But after running for a short time and the fluid is pumped out, the shifting gets worse sometimes slips and grabs. My mechanic tells me that in addition to the seal there is a bushing in the front that needs replacing as well. He has not seen the van, just heard my description. The problem for me, a 70 yr old with a willing mind but cranky old body, is cost (I am hearing in the $2K range). The van is clean, 135K miles, runs very good, and I like it alot but is probably not worth what a re-built tran would cost.
Any comments or suggestions appreciated.
Alan
Old 01-13-2012, 09:16 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
If all you're talking about is an r & r to replace the seal, I have no clue what "bushing" he could be talking about (except maybe the pilot bearing/bushing) 2k seems over the top excessive for $25.00 worth of parts and two hours work.
I wish I could make $1000.00 an hour.
