Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > VARARAM - Dodge Ram Performance!
VARARAM - Dodge Ram Performance! Vararam Industries was created to bring true racing technology to the street, the most efficient air induction systems on earth. Our air induction systems produce more Power and Torque, offering you more real world performance than any of the other intake system out there, We've been tested to be the best, compared to the rest and each time VR comes out on top. - Dodge Ram Performance!
Old 01-24-2012, 05:55 PM
JCummings's Avatar
JCummings JCummings is offline
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
JCummings is on a distinguished road
Default Paint Vararam intake, someone help.
I am looking for some help with painting a Vararam Intake cover. What steps did you follow to get good adhesion? Did you use high temp paint? Clear coat? Primer? Adhesion promoter? I plan on painting it Hemi Orange. Thanks for all of your help, your knowledge is invaluable. Also, if anyone has pics of their painted Vararam intake post it here!
Mods: Lowered and Blown.
Old 01-24-2012, 09:15 PM
moparornocar72's Avatar
Rep:630
I sitll haven't had time to paint mine........ask timmy if he has painted his yet!
14.268 @ 95 MPH Full Trim
Old 01-25-2012, 07:45 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
What material is it?
They make Hemi Orange in an engine block paint (obviously lol) I would just scuff it up a bit and paint the thing.
2011 Big Horn 4x4 -SnowWhite-
Old 01-25-2012, 08:02 AM
JCummings's Avatar
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
I believe it is the same type of plastic material the HEMI hat is made of
Old 01-25-2012, 01:44 PM
RPD RPD is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport Crewcab 4x4
RPD is on a distinguished road
I painted mine to match the color of the truck. I prepped by scuffing with sandpaper. Wiping down with rubbing alcohol. Primed with DupliColor primer. Two light coats and then one heavy. Dried according to instructions. Then did 4 light coats of DupliColor Bright Silver Metallic followed by a wetsand and one more heavy coat. Then applied 4 coats of clearcoat. Wet sanded before final coat. Turned out good have had it on now for about threee weeks. No signs of any peeling or anything like that. I was happy with my first attemp at painting. I just took my time and followed the instructions on the can.
Old 01-25-2012, 02:44 PM
I push the skinny pedal
Rep:3277
I would recommend the above steps, but I would also suggest using an adhesion promoter prior to the primer to get proper bonding between the primer and plastic.
Kurtis
Old 01-26-2012, 07:02 PM
JCummings's Avatar
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
so let me get this right. Scuff sand, adhesion promotor, then primer, paint, and finally clear? Could anyone explain the process to apply adhesion promotor. also, should I be using high temp paint? do they even make high temp primer and clear coat? thanks for all of the support guys.
Old 01-26-2012, 10:56 PM
Rep:3277
You don't need high temp paint, if the intake is getting over 110F than you're in serious issues outside of a hot intake. The adhesion promoter is treated just like any other spray bomb, make sure the area is clean, then spray 1-2 light coats.
The only time you need to be looking at high temp is if you're doing metal parts directly connected to the engine like the timing cover, heads, headers, etc. plasic parts do not need high temp paint as most paint will handle 250-300F and the plastic itself starts melting/softening at the same temp.
Kurtis
Old 01-26-2012, 11:39 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
You have to remember the great thing about Vararams...that lid is in a sealed area between the hood and the lower tray...with outside air being rammed in there like it stole something
And no...mine is still black.
Old 01-27-2012, 04:25 PM
JCummings's Avatar
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
Cdnoil,
Thanks for the help. My intake tracking info came yesterday so i need to get my sh!t together so that i can paint it. I feel like a teenage boy preparing for the prom! I want everything to go just right, so that i get the big finally!
