2002 dodge ram 5.9 misfire - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-25-2012, 11:39 PM
smitty0486's Avatar
smitty0486 smitty0486 is offline
Vehicle: 2014 Ram 2500
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
smitty0486 is on a distinguished road
I've had the same misfire issues on my truck lately with rough idle at start up. I just did a tune up and it helped a little but still has a rough idle after the truck has been sitting for a whil, so me and a mechanic friend have about determined its the injectors in my case, dont know if this is the same problem earlier mentioned or not but just thought I'd give my input haha. ill prob be changing injectors out soon so hopefully this will solve my problem!!
Old 02-29-2012, 09:15 AM
augiedoggy's Avatar
augiedoggy augiedoggy is offline
Vehicle: 1996 Dodge ram 1500
Rep:12
augiedoggy is on a distinguished road
Originally Posted by RAMING IT View Post
Any luck?? I agree with it possibly bieng the crank sensor.
+3 on that.. I have a missfire issue im trying to track down too...I have the new crank sensor already but havent gotten the old one pulled out (bolts are out though) they are tough to get to but not as bad with a body lift....I've replaced injectors and tuneup parts as well as leakdown and compression test myself...
If its not the sensor I fear a collapsed lifter or worn cam lobe... I just pulled a cracked header on the side effected by the misfire and am replacing them with ebay stainless ones (which are identical in design ironically superior welds than my old pacesetters but that for another thread) On the old header you can see the exhaust holes are all black but cylinder#1 (the one giving me misfire code p301 under load) which is light brown so its lean somehow even which new injectors...valve issue not opening enough? Being that it all started after the tranny was rebuilt I'm hoping the crank sensor just got damaged when they removed or installed the transmission since its right there..
Old 03-02-2012, 05:21 AM
Vehicle: N/A
Rep:1045
just finished my plugs and wires... problem solved.
