Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 01-25-2012, 03:58 PM
oh58pilot oh58pilot is offline
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
oh58pilot is on a distinguished road
Default Engine Warm up time
Hello all,
I'm having a debate about proper warm up time for the Cummins with a friend. It seems he thinks that his engine should be warmed up 15-30 minutes before driving. I think that is WAAAY too long.
I generally start my engine and wait till I have oil pressure, kick it up to about 12-1500rpm for about thirty seconds to a minute,(depending on outside temp), then start driving....slowly..keeping the rpm around15-18 for a few miles so that it gets to operating temp faster. He says I am damaging my engine by making it warm up too fast. I say he is damaging his engine by making it stay below operating temp too long. I also think he's wasting fuel and costing himself a lot of dough. I realize that colder weather would take a little more time, but... 20-30 minutes?
Any thoughts???
Old 01-25-2012, 05:04 PM
I push the skinny pedal
Rep:3277
Warm up time is really dependant on temperature with the diesels, it also makes a difference if you have a high-idle function as well since that cuts the warm up time down. Generally you should allow a diesel to warm up in the winter for at least 5 min since the most damage occurs to a diesel when it's cold due to the low oil pressure not lubricating the piston skirt properly. The diesels are a lot harder on the sleeved walls because they run at a much higher chamber pressure and you can start having ring/side wall scoring issues if you don't have the proper lubrication; you can also overheat the top piston ring and crack the top of the piston.
Unless you're running a propane heater under the engine (which we do is extremely cold temperatures!) you can't heat the block too fast on a diesel, but you can definately do damage by putting load on it when it's cold.
Kurtis
Old 01-27-2012, 01:23 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
with Kurtis. The big killer is lubrication, which is why oil pan heaters are quite popular with diesel owners in very cold climates. I still have 2 diesels that I run year round, one in a tractor, the other in a large portable generator. As both have an extreme amount of hours on them. I use both an oil pan heater and a recirculation block heater to ensure the oil flows. In -30 deg C (about -20 deg F), I warm them up for at least 5 minutes, then load them lightly until they are at full operating temp. One of the engines has just over 8000 hours, the other is unknown, as the hour meter quit a few years ago at 12,500 hours. neither engine has ever had more than basic maintenance done to it. I'm not a diesel guy, but have followed the recommendation of 90 year old that ran diesels all his life, and so far it's paying off for me.
brad
Interested in one of my mods?
Old 02-04-2012, 06:39 AM
Nitro1 Nitro1 is offline
Vehicle: 96 dodge ram 3500. 4x4
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Nitro1 is on a distinguished road
These pros are on the money. I use a block heater on mine. put it on a timer so she aint on all night. She starts real easy on real cold days. I use one of those high tec pedal props to keep rpms at 1200. lol . 5 -10 min. Then take it easy on the old girl till she warm up. Man if i warmed my truck for 15 -30 mins my neibhors would shoot me.
Old 02-05-2012, 09:09 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
It depends I run a cummings 5.9 in a 24 ft. box truck with 350,000 km. I never use block heater and let it warm up 10 min. No issues with it for the 6 years ive ran it
Old 02-05-2012, 09:11 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Now how you warm up your truck is the same way I warm up my gasser truck. Seems to work well.
