Old 01-26-2012, 11:38 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
Default Potential issues with lowering?
I am planning on dropping my 09 QC with a 2/4 drop kit either the Belltech or McGaughys(not sure of spelling) just going with the basic kits with stock shocks. question is has any body had any wear issues with time i.e. abnormal tire wear or ball joint issues? how hard is it to get the front end alligned with the kits. also any other upgrades or parts that might make one or the other of these kits better?
Old 01-28-2012, 12:15 AM
icywhite's Avatar
icywhite icywhite is offline
Vehicle: 04 dodge ram
Rep:29
icywhite is on a distinguished road
you will need to get an allinment or it most likely have a problem with wear as far as problems with getting it is to far out you can get a camber kit for around a 100 buck that will correct it
2/4 drop,h.o. cams,4.56s posi, stage 2 cai, 70mm tb, 180t, cutouts, efan, centerforce dual friction clutch,short throw shifter 24%, sct(tuned by flying ryan), high flo-Y, 3 inch exaust , jbl headers, 2013 intake manifold, nitrous, killian ported heads,leds and hids on all lights,
Old 01-29-2012, 08:25 PM
25bduse 25bduse is offline
Vehicle: 2011 Dodge Ram Quad Hemi
Color: Rugged Brown
25bduse is on a distinguished road
Bump...same here
Old 01-29-2012, 11:04 PM
P Rod's Avatar
P Rod P Rod is offline
Vehicle: 2011 Ram 2wd Crew Cab
P Rod is on a distinguished road
If I could make a recommendation is to spend the extra money (if buget allows) and get the complete kit with the shorter shocks that are designed for the shorter, stiffer springs. I really think you will be happy you did. If you think about it, stock shocks on a 4" drop meens your shocks will all ready be compressed 4" before you even haul/tow or even hit a bump. From what I have heard Bell-tech and Mc-G both make good kits. I have the GF 2"/3" complete kit on my Crew cab, and love the way it looks/rides. Re alignment no problem, no odd tire wear after over 10k miles on my kit. Good Luck
CrewCab Sport*Sunroof* Navi*3.92's*Ground Force 2/3 drop*Back Flip F1*Mufflex 18"*BedTred
Old 01-29-2012, 11:06 PM
Stuck2theAxles's Avatar
Stuck2theAxles Stuck2theAxles is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT BigHorn
Color: Gray
Rep:108
Stuck2theAxles will become famous soon enoughStuck2theAxles will become famous soon enough
There really are no issues that can come about by lowering the truck, obviously your going to have to align it that a givin, the perfect kit would be have the beltech kit with the hardware from the rear of the McGaughys kit ( trac bar bracket and end links ) i personally like the McGaughys kit but the only draw back is using the stock shocks cuz they are alittle long and when you put the truck up on a lift it puts the sway bar in an awkard position cuz the links are so short , id say your best bet is to get the McGaughys then order the belltech rear shocks that would be perfect when i had my kit installed on my 11 CC i got some offroad limit straps and it was perfect, why spend 100 when you can get straps for 35 haha, if you want a kit i have my McGaughys kit forsale rite now
2011 CCSB Sport 2WD - McGaughys, FOOSE , shaved clean and newly added DIABLO SPORT !!
2012 CCSB Lone Star 4WD - McGaughys , KMC, shaved clean
2012 CC 2500 Cummins - Thuren, Fox , H&S w deletes upstairs and down
Old 01-29-2012, 11:30 PM
Ramfd's Avatar
Rep:150
thanks guys for the info, this is exactly what I was looking for. stuck2theaxles I saw your post in one of the other threads. I am very interested in your kit. I have income tax money coming in wednesday. My wife was gracious enough to allow me about $1000. one of my top priorities is to get a hard tonneau cover then I am planning on that kit if you still have it by then.
Old 01-30-2012, 08:20 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Adjust/correct your pinion angle if when needed.
Old 02-01-2012, 10:03 PM
Ramfd's Avatar
Rep:150
So i think i am going with the Belltech kit with the street performance shocks, my question now is, is there a way to buy just the sway bar end links and track bar bracket seperatly to add to this kit? also how do i adjust/correct the pinion angle? shims i assume? also, what happens to the bumpstops up front, I think i have read they have to be cut? what kind of fabricating is involved in the front? I am jsut trying to make sure i dont have any surprises when i get to this.
