Old 03-25-2012, 04:31 PM
Zeus Zeus is offline
Vehicle: 2011 Ram 2500
Color: Rugged Brown
Rep:27
Zeus is on a distinguished road
Curious as to what RPM you guys that have done the swap are running at 65 and 70? I am doing mine on the 2nd and a buddy was trying to tell me it will be turning high RPM. I told him he was full of crap since the 35" I have now and the 37" that I am going to tire helps that out. Just curious thanks
Old 03-26-2012, 09:40 PM
InterpunX's Avatar
InterpunX InterpunX is offline
Vehicle: 2009 Dodge Ram
InterpunX is on a distinguished road
at 60 mph i run roughly +-1900 rpm with 35" tires, that's from what i remember. Here's a link to a calculator to give you a better idea.
Old 03-26-2012, 09:50 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
At 70mph I run about 2200ish rpms on 37s. If you slap it in 5th/manual mode it'll add a couple hundred rpms.
[CENTER][SIGPIC][/SIGPIC]
Old 03-26-2012, 09:51 PM
Color: Rugged Brown
Rep:27
cool thanks guys
Old 05-08-2012, 04:44 PM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
Nothing is as simple as it seems I see. The Motive 9.25 4.10 aren't fitting in the housing. THe are rubbing when everything is set to correct backlash according to my mechanic. I have a call in to Motive, but this is just way frustrating.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 12" Dayton/Net Audio Sub, JL Components, ARC Audio Amps, Magnaflow 14 inch, Granite Alloys sporting 34" BFG T/A KO, HID conversion full blackout.
Old 05-08-2012, 04:49 PM
candy08's Avatar
Rep:213
That's odd, keep us posted.
Why 4.10 and not 4.56?
Old 05-10-2012, 04:09 PM
Rep:27
Alright, Ron(Ron's Machine Shop) and my mechanic discussed this pretty extensively and are pretty sure that there is just some excess material on the inside of housing that the gear is rubbing on. Not sure all the details but will find out on Tuesday when the local shop attempts to install another set.
Old 05-10-2012, 05:15 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
For KyleMc; according to Allpar, "New ZF( Zeppelin Foundation ) axles were being made in Marysville starting in 2010." Whether the installation of said new axles were put on all Ram trucks during that year?; Thats a good question. I remember back about that time, there were rear end issues going on with ineffecient sustainment of gear oil to the rear gears, and according to the recall, affected somewhere near 50,000 or so trucks. Hence the recall and changing of certain internals and the rear diff cover; most likely to verify that particular truck had the recall repair performed. I believe the 2011's and 12's definitely come with the new ZF axles and can be verified by the different shaped pumpkin/diff cover. FYI if you didn't already know; the ZF company has been around since 1915 for the development and production of transmissions for airships and vehicles. Today, the group's product range comprises transmissions and steering systems as well as chassis components and complete axle systems and modules. I guess it's safe to say, these guys are from the old/new school and hopefully for all of us Ram owners, it's a step in a positive direction.
Old 05-10-2012, 05:24 PM
Gantman's Avatar
Rep:974
Oh and for Silverstar777; nice upgrade/mod to handle the big meats man! You could probably go even a little bigger diameter size in tire and get closer to that 1800rpm @ 70mph which could get you back up to the 20+mpg mark. That's if highway commuting starts to take a hold of you. If your beast is primarily round town and heavy offroad, then disregard my last over. Romp and stomp bud!
Old 05-11-2012, 12:23 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Why not just got to an R/T rear diff with the stock 410s and sell your stock parts off?
2011 Big Horn 4x4 -SnowWhite-
