tonneaucovered.com
Old 01-27-2012, 07:50 AM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default plus/minus selector
What actually is happening when the minus button is punched on the gear selector knob in my Ram? My owners manual seems to indicate that any of the 1-4 numbered ranges can be selected while traveling at any speed.
On my previous Silverado, I'd always have to slow down before descending a long steep grade in order to choose a lower gear appropriate to both the downhill as well as the my current speed. It didn't like to be downshifted until my speed had dropped to match the chosen range's normal operating speeds.
Guess what I"m asking here is this,...is my Ram's computer(s) somehow automatically slowing my vehicle speed gradually and downshifting until it reaches the gear range I've chosen? Like maybe cutting fuel delivery?
Old 01-27-2012, 09:59 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
It is the highest gear that the trans will shift into, plus it will electronically disable the MDS system.
Old 01-27-2012, 10:10 AM
bonehead bonehead is offline
Vehicle: 2011 Ram 1500 Quad 4x4
Rep:24
bonehead is on a distinguished road
Basicly if you traveling down a hill and put the shifter say into 2 on the dash the transmission WILL NOT go there if the speed is to great. It may drop to 4 or 3 but again not until it feels the speed matches the gear selected. The same is true when upshiffting. If you forget to upshift the transmission will do it anyway if the engine RPMs are to high for to long.
Old 01-30-2012, 04:48 AM
Dancianne's Avatar
Rep:136
Thanks guys ! Guess I need not hesitate to use the minus button anymore.
Love the technology !
Old 01-30-2012, 08:33 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:450
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
You can enter ERS mode (by tapping the minus button) at any speed, but you'll be limited in how far you can tap it down (how many gears you can go down). It will not allow a manual downshift if it would overspeed the engine.
