What is needed for a After Market Nav install - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-27-2012, 01:13 PM
garcia0106 garcia0106 is offline
Vehicle: 2012 Ram Express Crew
garcia0106 is on a distinguished road
Default What is needed for a After Market Nav install
I have a 2012 Express with the basic stereo not alpine. No volume control on steering wheel. I just ordered the Pioneer Avic Z130BT. Am I right to say that I need the PAC C2R-CHY4 and antenna adapter?
What did you guys use to cut the plastic on top?
Old 01-27-2012, 02:04 PM
1500ram12's Avatar
1500ram12 1500ram12 is offline
Vehicle: 2015 Dodge ram 2500
Trim Level: Tradesman
Color: Granite Metalic
Rep:81
http://www.*************/f75/install...r-4th-gen-502/i believe you don't need to cut any plastic just the metal mounting bracket that holds the factory radio in. can't get the link to show but where **** is just enter ram forum .com
2015 Ram 2500 Tradesman, 275/70/18 Fierce Attitude M/T, 18x9 ?wheels, Custom 13' OEM projectors, 55w 5k HID's, 7" premium display cluster swap, Alpine INE-Z928HD HU, RF 200s amp, 2 10" MTX subs, Factory bumper with fogs added
Old 01-27-2012, 02:16 PM
The ***** don't show. Can you put the link just leave out the www.
I read in the forums I have to cut 1/2 inch of plastic
Old 01-27-2012, 10:45 PM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
http://www.ramforumz.com/showthread.php?t=99778
You do have to cut the plastic. I installed the same unit. Yes you have the correct pac adapter. You need the steering wheel control adapter too.
Old 01-27-2012, 10:46 PM
rtkman's Avatar
Rep:167
Oops sorry no steering wheel controls. Just the one adapter then! I used a dremel cut off wheel to cut the plastic and a air hacksaw to cut the steel brace.
Old 01-27-2012, 11:11 PM
So I just need the PAC adapter and the kit to hold the unit. I think Metra makes one. Do you recommend the kit you use if so what is the model number?
I am very afraid to cut the plastic. Did you cut the top or the bottom and about how much did you cut? Can you tell me what is the model number of the Dremel you used as well as the blade you used on the Dremel? (I will order it from Amazon) It has to be a perfect cut right so it doesn't look sloppy?
Old 01-27-2012, 11:40 PM
rtkman's Avatar
Rep:167
The pac adapter you listed is the one I used. The C2R-CHY4. I cut to here. See the red line in the pic.
I used a 1.25 inch cutoff wheel. Like this. 1 inch might be better. I had trouble making the edge clean near the corners because of the size of the wheel. Maybe 1 inch would be better. Just take your time and keep a steady hand. Wear safety glasses!
http://www.amazon.com/Dremel-426-Fib...7721835&sr=8-2
Old 01-28-2012, 12:14 AM
Oh I see so the plastic you cut you wont actually see once you put the stereo in so it doesn't have to be perfect right?
What are the plastics to the left and to the right of the stereo once installed? Is that the Scosche you bought? On your pictures it looks like the left side is stinking out and the right side is sunk in. What do you suggest?
I was thinking of using this Metra
Old 01-28-2012, 12:19 AM
I was also told I need an Antenna adapter that is around $5?
Old 01-28-2012, 07:51 AM
rtkman's Avatar
Rep:167
Right you cant see it anyways. I did mine very neat because i'm anal that way.
Yes that's the Scoche brackets you see in mine. I took that pic before I was done. Its even now. Try the Metra and see how it goes. I wasn't happy with all the screwing around I had to to to make the Scoche fit.
Yes you need the antenna adapter too.
