Old 02-02-2012, 12:50 PM
garcia0106 garcia0106 is offline
Vehicle: 2012 Ram Express Crew
garcia0106 is on a distinguished road
Did you connect the (pink) speed signal cable? If you did where did you tap into the speed sensor?
Also did you connect the Orange illumination cable? If so where did you tap into that?
Thanks in advance
Old 02-02-2012, 06:26 PM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
The pink on the Pioneer harness goes to the purple/white wire on the pac harness. The orange/white wire on the Pioneer harness goes to the Orange/white on the PAC harness. All of the connections are made between the Pioneer and the PAC harnesses. You dont "tap" into the harness on the body at all. When you are done you should be able to just unplug the main plugs and return the vehicle to stock instantly with no disturbed wires.
Old 02-02-2012, 06:33 PM
Rep:2657
The after market bezel covers the cut area
i saw one picture of a miss cut & you could NOT see it with the bezel on
