Old 03-11-2012, 01:49 AM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
I came across this, after someone suggested I look into steering column bushing for my death wobble. It subposedly reduces the play in steering which can be caused by the spring mechanism in the steering column. It's about 60 bucks, and there is a video:
I imagine there are other alternative brands out there, but this is the one I came across:
http://www.rocksolidramtrucksteering.com/
Old 03-12-2012, 10:13 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
That bushing didn't help me and was a pain in any area that has extreme temp changes as it will shrink when cold and makes turning the wheel harder.
I agree with the red head box and the brace. Have you checked your steering shaft the joint wears out and needs replaced. I got a borgerson shaft.
Other than that if your track bar is good most of the time your upper joint wears out quick. Turn the wheel while watching for movement. Lastly I like the lukes link on a factory lifted truck.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
