Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 01-28-2012, 12:54 AM
jdkennedy34 jdkennedy34 is offline
Vehicle: 2011 ram 1500 quad cab
Trim Level: big horn
jdkennedy34 is on a distinguished road
Default Anyone else have that popping noise
Anyone else have that popping noise in the frontend over bumps in turns? Strut? Cvs? Wanting to put a leveling kit on but want to figure this out first. So the dealer cant blame it on the lift.
Old 01-29-2012, 02:15 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I know the sound you are referring to. I have yet to determine what it is.
I moved this thread to the suspension section. Hopefully someone that has discovered what this is will see it and respond.
brad
Interested in one of my mods?
Old 01-29-2012, 12:17 PM
gtahemi11's Avatar
gtahemi11 gtahemi11 is offline
Vehicle: 2011 Dodge Ram 1500
gtahemi11 is on a distinguished road
It might be what I dealt with. First I had a bad body mount on the front passenger side that was causing a creaking noise almost like a old rocking chair.
Once that was replaced almost the same noise was still their but only when a heavier set person sat in the passenger side and I hit bumps or came to a stop.
Come to find out the heat shield on the passenger side between the frame and the body had a stud that was digging into the frame of the truck when their was weight put on it.
They grinded down the stud to the point it wasn't hitting anymore and the noise went away.
The dealership put in a Service Report and took pictures because they never seen it before
Old 01-29-2012, 12:40 PM
09nitetrain 09nitetrain is offline
Vehicle: 2006 raqm 1500 trx4 hemi
Trim Level: trx4
Color: blue
Rep:20
09nitetrain is on a distinguished road
is it on tight turns that you guys hear and feel it?
Old 01-29-2012, 01:11 PM
I have noticed it a few times in a tight turn but mostly it seems like when im turning and my suspension has to flex. Like going from a flat surface to a hill.
Old 01-29-2012, 02:17 PM
Trim Level: trx4
Color: blue
Rep:20
i know there are 2 pieces of metal on the lower knuckle and lower control arm to keep you from turning the wheel to far, acts as a stop. this could be what your hearing, it causes a popping or a snapping noise. try taking so wheel bearin grease and putting a thin layer on each side of the truck on the lower knuckle. its usualling on the back side/ closes to the door. if i get time tomorrow i'll put my truck up on the lift and snap a few photos of what im talking and youll soon understand, but if you look you might see where metal has been making contact.
Old 01-29-2012, 03:38 PM
brad12kx's Avatar
Rep:2581
I have noticed this at all steering angles from straight ahead to full lock. I have noticed that the popping is least noticeable when straight, and increases with the amount of off center steering. It is a popping sound that I associate with failing struts, or a failing/worn-out upper strut mount.
I have never heard this at high speeds. It is most noticeable when pulling into a gravel parking lot at low speed where the lot is great need of grading (washboard).
brad
Old 02-01-2012, 10:10 PM
gtahemi11's Avatar
yeeup you guys are dealing with the same issues I was dealing with. Its either the body mount (apparently dodge redesigned it mid 2011).
Old 02-01-2012, 10:29 PM
dodger2107 dodger2107 is offline
Vehicle: 2011 Ram 1500 Express
Trim Level: 1500 Express
Color: Hunter Green
dodger2107 is on a distinguished road
Default noise
I also hear it on my express,especially when going over bumps..going to the dealer tomorrow...also have them check out the torque convertor
