tonneaucovered.com
Old 01-31-2012, 12:43 AM
Dodge891's Avatar
Dodge891 Dodge891 is offline
Vehicle: 2001 dodge ram
Trim Level: Single cab short bed
Color: Vader Black
Rep:48
Dodge891 is on a distinguished road
I just sanded my stuff down reall nice and then cleaned it,primed it, painted and cleared it. Everything turned out amazing
Sparky says RAM IT
Old 01-31-2012, 01:41 AM
ACLARK93's Avatar
ACLARK93 ACLARK93 is offline
Vehicle: 2004 Dodge Ram
Color: Gray
ACLARK93 is on a distinguished road
i tried scuffing, then priming, then painting mine and it still came off , the plastidip but worked great for me. Hope it comes out looking good
>ii@
Old 01-31-2012, 02:59 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
I plasti-dipped mine both front and rear too. Then I used the paint to match stuff from the auto parts store and now it looks like a sport model bumper front and rear. Overall cost me $50 and an afternoon. Has held up good for 6 months so far. Even with highway driving everyday to work. Only peeled where I scuffed a fence post at work.
Also, used a few coats of clear on top too.
Old 01-31-2012, 06:50 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Do it yourself man, its easy just TAKE YOUR TIME
http://www.ramforumz.com/showthread.php?t=95962 <--- Clicky
2011 Big Horn 4x4 -SnowWhite-
Old 01-31-2012, 06:52 AM
SS4Luck's Avatar
Rep:310
PM me with any questions too. ITs more time consuming than anything difficult wise, but Ive done a lot of painting before
Old 01-31-2012, 02:11 PM
Morlow Morlow is offline
Vehicle: 2002 Dodge Ram
Rep:20
Morlow is on a distinguished road
Hmm. Did you scuff up the chrome before you Plasti-dipped it? If so what grit should I use to scuff? And do you scuff by hand or use a sander?
I suppose even if it didn't turn out good $50 isn't a big loss. My main concern is cold temperatures. I will be working in Yellowstone National Park from April-November and it is usually lows below freezing in April and late Oct-November. It seems like since it is plastic it would shrink/expand and come off.
Old 01-31-2012, 02:16 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
Why not sell your crome stuff on E-bay and buy new black direct from MOPAR ? I would think this would be close to an even swap money wise.
Old 02-02-2012, 12:38 AM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
i painted my chrome grille to match the black, sanded with 300 grit, cleaned then primed, 3 coats of paint then 3 coats of clear. not too bad for a novice painter.
before
after
Old 02-02-2012, 01:10 AM
Rep:20
Thanks for the info. I think I will definitely try at least my grill. If I think that goes well I will do the bumpers.
I still have quite a few questions.
-Where do you recommend I buy the primer and paint from? Just my local Autozone?
-Is a product like this worth looking at? http://www.autozone.com/autozone/acc...er=467217_0_0_
-Did you sand by hand or use a sander?
-Does it matter what color primer I use?
-I am wanting a flat black color for it all. If I put clear coats over the flat black will that make it glossy? Do you think it will be durable enough with no clear coats?
Old 02-02-2012, 09:22 PM
SS4Luck's Avatar
Rep:310
Check for answers in red
-Where do you recommend I buy the primer and paint from? Just my local Autozone? You can get everything needed from autozone. I used all Duplicolor products for mine. Just make sure to get an adhesion promoter and an etching primer wouldnt hurt either
You wouldnt need that. It is for bumpers that are flexible not metal ones like our Ram bumpers
For the initial sanding a sander wouldnt hurt for smoothing i wouldnt do it with anything but my hand for better control. at the end of the day it is your choice though
not really if your just going for a "plain" color
They make a matte primer. If you are going for that look it would be worth it to track a few cans of it down so you did have a clear over it. Otherwise you would be doing monthly touch ups
