Old 01-28-2012, 06:14 PM
Whiskey26's Avatar
Whiskey26 Whiskey26 is offline
Vehicle: 2005 Dodge Ram 4x4 Hemi
Rep:50
Whiskey26 will become famous soon enough
Question Advice wanted on a Mystery Mod
Ok, so I bought my truck 4 months ago and havent done anything major other than tires/wheels and some LED's. The truck came with an older "Valor" CD/DVD/NAV system with a 7" touch screen monitor. That was cool but wasnt the main selling point and I didn't ask much about it when I bought the truck. The salesman said that there were a couple of dead remotes in the glovebox for it. The stereo hasnt been one of the top priorities for me but I got a suprise today. I found the remotes and there was one that was in two pieces and looked pretty crappy. I cleaned out the corroded battery, glued it back together, popped a new battery in and started pressing buttons.... Low and behold Ive got an alarm with keyless entry and a lil blue led indicator. Cool enough I thought because until then I didnt have keyless entry. I then tried the red button, which I thought would be the panic button, to hear it sound off. It didnt work so I hit it again and the remote beeped at me and my truck CRANKED ITSELF....
This is the remote for It and Im trying to get some advice on problems/issues that may arise from this mod as it is one that I hadnt even considered doing. Dont know much about the Python but I found the control box and a shock sensor tucked under the steering column. Any thoughts?
"Fear is a reaction. Courage is a decision." - Winston Churchill
Old 01-28-2012, 06:22 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
6.4L HEMI Driver
Vehicle: 2014 Ram 2500 CC 6.4L HEMI
Rep:74
ShiftJockey will become famous soon enough
hmmm...sounds like an aftermarket remote start in addition to keyless entry. Did the truck start?
Michael
2014 BIG HORN CREW6.4L HEMI
Old 01-28-2012, 06:40 PM
Whiskey26's Avatar
Rep:50
Yes, cranked right up. Through trial and error I figured out that the brake pedal cancels it out. Putting the key in and turning to on allows brake and shift into gear. Alarm works, keyless entry works, and now it starts itself....
Old 01-28-2012, 07:04 PM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
I have owned other auto start alarm systems from Clifford and Directed Electronics and they worked flawlessly. I might suggest getting a back up remote, if you didn't already have one in the glove box, in case that one gives you any trouble. You could also have an installer look at it to check the installation, just to make sure it was done properly, wouldn't want to be stranded with a malfunctioning alarm system.
That sure is a nice surprise to find, wish it happened to me too.
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
Old 02-03-2012, 09:15 AM
Chris36608 Chris36608 is offline
Vehicle: 2004 Ram 1500 4x4
Chris36608 is on a distinguished road
I did the exact same thing, almost. I bought the truck, and it had an aftermarket Viper alarm system. Pushed the red asterisk a million times, thinking it had a panic feature and wasn't working. I accidentally leaned against the tailgate with the keyless entry in my pocket, and vroom. Truck started. Turns out you have to hold the Lock, Unlock, and press the asterisk. Great surprise.
- Christopher
04 Ram 1500, 05 Neon SRT-4 400hp, 2002 Hayabusa 220hp Stolen spring 2011, 68 Mustang 302/5spd
Old 02-03-2012, 09:51 PM
2k84by's Avatar
2k84by 2k84by is offline
Vehicle: 2014 Dodge Ram 1500 SLT
Color: silver
Rep:19
2k84by is on a distinguished road
Python is the same as clifford/viper. just different options available. If i remember right clifford is the top, followed by viper, then python (all are made by DEI)(similar to caddy, chevy, gmc) python is still a good brand though...everything dei makes is good. I would purchase another remote for it, you should be able to find the remotes on ebay. You said you found the brain (control box), it should have the part number on it so you can order another remote that works for it.
Great find!
BTW, pushing AUX and lock/unlock should "silence" the alarm beep when you lock/unlock if you care....or have neighbors like mine who bitch and moan about any sound after 9pm
Old 02-03-2012, 09:57 PM
WhiteGoat2011 WhiteGoat2011 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Big Horn Crew Cab
WhiteGoat2011 is on a distinguished road
When I did alarm installs on the Clifford and directed electronic alarms, there was a "pit-stop" option. With the truck running if you did the remote start option it would allow you to remove the keys while leaving the truck running.
Old 02-04-2012, 03:59 AM
trojanman22 trojanman22 is offline
Vehicle: 2010 Ram 2500 Laramie Megacab
Engine: 2010-2012 409ci (6.7L) Cummins Turbo Diesel 305hp 610lb/ft (Chassis Cab)
Rep:13
trojanman22 is on a distinguished road
pushing the break is an anti theft feature with those alarms. if you were to remote start the truck and someone jumped in it and tried to take off, when they pushed the brake to put it in gear the truck will die.
