Place your Ad Here!
Old 01-28-2012, 11:26 PM
ShawnC13's Avatar
ShawnC13 ShawnC13 is offline
Cheap Canadian Labour
Rep:2044
ShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond repute
Default Levelling 2008 TRX
What are the things I should be looking out for. I read on here about angles up front but can't find that thread now. I am sure someone has done it already. So if you have any info that would be great
Old 01-30-2012, 12:17 AM
ShawnC13's Avatar
Rep:2044
I couldn't have stumped the Z on this one.
Old 02-07-2012, 08:38 PM
ShawnC13's Avatar
Rep:2044
Ok so I couldn't find any solid information online so I emailed the local Spring and 4X4 Shop with this "
I have been reading that I can't just get any leveling kit that the TRX have different front struts. Do you know if this is true and are you able to level out my Truck and if so what cost am I looking at?
Thanks
Shawn"
Here is what he came back with
"Hi Shawn,
Yes you are correct that the trx4 trucks have a different front suspension then the others. There is really only one good way to lift the front of those trucks. That is with the bilstein 5100 series height adjustable strut. Basically the factory trx4 strut is .7" taller then a stock strut so if you try to put a level kit spacer in it over extends everything and can lead to vibrations and other issues. The bilstein strut replaces the longer factory strut and gains about 2" over stock height. "
I think this is a pretty straight up answer. One of my co-workers has used his shop and was extremely happy with it. Has anyone installed the Belsteins and approximately how long did it take? Also where is a good place to buy them?
Old 02-07-2012, 08:58 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2015 Ram
Trim Level: sport
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
bilstiens are the way to go, they are addjustable from 0-2" i think, ride smoother and have a lifetime warrenty...summit has em for 107 each
http://www.summitracing.com/parts/BSN-24-186988/
2015 blacked out sport 4x4 qc
Old 02-10-2012, 11:01 AM
ShawnC13's Avatar
Rep:2044
Thansk I will check that out!!
