Old 01-29-2012, 06:05 PM
Hemi flash Hemi flash is offline
Vehicle: 2011 Dodge Ram SPORT Crew
Trim Level: SPORT
Color: BLack
Hemi flash is on a distinguished road
Default Ignition switch Hunt
Appreciate any suggestions for accessory lighting the ignition switch to make it easy to find in the dark when the 2011's Ram dome lights have been turned off . Was thinking about installing an LED puck light but don't want to mount anything with screws.
Anything available out in the accessory world such as a stick on glow in the dark ring installed around the ignition switch hole ??
Old 01-29-2012, 10:06 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
If you hit the unlock button on your key fob again it should turn the dome lights on again for you.
