Coolant leak - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-30-2012, 10:36 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
I a hoping to be able and do the pressue test tomorrow, I am borrowing one from a friend. Then if I need to I will shoot to a dealership and see if they can show me the vent you guys are talking about.
Old 02-02-2012, 08:46 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
I may be late to the game but the vent you are looking for is on the passenger side of the truck, under the hood on the firewall. Looks like a small solid hose poking out. Its the same place your a/c condensation leaks from as the a/c condenser and heater core live in the same HVAC box. How did the pressure test come out? Are you losing any coolant? Does the "syrupy" smell coming from the defroster smell like the same stuff that in your radiator?
I was losing a small amount of coolant, and couldnt figure out where it was going. I never got as far as doing a pressure test though, as the first cold snap of 2011 where the heater was needed revealed much the same smell you are experiencing. When you have a heater core leak in a truck like ours there are only 2 things you can do to fix, this:
Or this:
Sure it'll suck, but it'll make you a man
Old 02-02-2012, 10:41 PM
Rep:25
I did the pressue test and it showed that there is a leak, small on but there is a leak. The pressure went down by really slow. Couldn't find a leak though. I actually didn't smell the fluid in radiator I'll do that tomarrow. I did check the resevior on the coolant, and it is below the cold line pretty good, can this cause anything?
One of my hoses was pretty soft as well, so I was thinking of changing all hoses first, do another pressure test to see if that did it, and if not maybe yank the truck apart
Old 02-02-2012, 11:10 PM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
Can you see any coolant leaks coming from the engine, waterpump, hoses etc? If so that may be where your coolant is going. Anti freeze has sort of a syrupy smell, and there is only one way to get that smell in the cab with the use of defrost or heat only, and thats a leak in the HVAC box, the heater core is the only thing in there that anti freeze running through it. As stated before, your floor no longer gets wet unless the thing grenedes in there as any extra will siphon off out of the a/c drain.
In my particular truck the floor immediately under the box didnt get wet, but when I pulled the carpet back to pull the dash out, the carpet padding was wet mid way to the seat.
If you end up doing your core, or anything else that will cause a loss of coolant, I suggest you change everything that will cause a coolant loss as the G-05 anti freeze our trucks take isnt exactly cheap at $17 a gallon.
Old 02-04-2012, 11:02 AM
Rep:25
Yea I am probably going change heatcore, just gotta wait on the money, I don't know how much it'll cost me for a shop to do it :/
Old 02-04-2012, 11:26 AM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
I dont know where you are located, but in my area the average quote was around $800. Its not really a bad job to do yourself. I read some threads about removing the dash after the fact that would have saved me a lot of time had I read them before hand. I will PM you with this information later, its not really as bad as it looks. Even if you decide not to do it yourself or it ends up being some other problem, this is still good information to have.
To do this yourself, some things you may want to keep in mind before hand:
- You will have to evacuate the a/c system to be able to pull that black box completely out of the truck to access the heater core. Having the proper quick disconnect tool at hand to disconnect the a/c lines will save you the frustration of going to the parts store mid job. I caused myself a blood pressure spike because I thought I would be able to get at it without removing the box, boy was I wrong.
- Regarding the a/c lines, once you have everything back together, before you recharge the a/c with 134a, make sure (chec- triple check) that the lines are secured back together. I just pushed them together and forgot about it without making sure they "clicked" together and 4 days later one of them blew off. So I had to re vacuum the system and recharge. It was like throwing $60 out of the window.
- While you are already in this far, consider installing a heater treater kit or replacing your blend doors. These are known to fail on these trucks and the only way to fix them is to take everything apart again.
- If your dash is sun damaged (cracked etc), find a replacement panel that goes near the windshield before you start, because it will shatter on you when you try to unsnap it. The shops wont include this in their original estimate but this piece is about $200 new. If you have the luxury of searching on ebay or in a junk yard to find one in a good condition it will help. In the end I ordered a new panel and bought a color matched cover for both the main dash and that panel.
- The job may get irritating, and piss you off. But when its all put back together and you dont have half of what you would have paid a shop for the repair in it, the sense of satisfaction is overwhelming, as is the fact that you now know your truck better then most people ever get to know their cars.
Old 02-08-2012, 11:25 PM
Rep:25
Yea if you could PM me the info that would be great. Also if you can think of anything else I should do while its all apart that be awesome.
I am going have to look for a new dash mine is cracked, so I will be looking now at some junk yards.
Old 02-08-2012, 11:58 PM
Tommycat Tommycat is offline
Vehicle: 2004 Dodge Ram
Rep:22
Tommycat is on a distinguished road
bigdaddy: I agree with ya on that one. It's frustrating enough getting the dash apart to get the heater core out. don't make it worse by not replacing the blend door and having to do it all over again.
Simple trick I did was to pull bolts, then when I moved whatever I was removing out of the way I put those bolts back in part way. Kept me from going "Where did this bolt come from..."
Pulling the dash is not hard, just tedious. Oh and save yourself a bit of headache and go ahead and remove the driver seat so you can get the steering wheel further out of the way.
