Old 02-02-2012, 11:07 PM
Bugaboo232's Avatar
Bugaboo232 Bugaboo232 is offline
Vehicle: 2011
Color: Deep Cherry Red
Bugaboo232 is on a distinguished road
Looking at the rear wheel well you can't tell it has a body lift, the stock wheel wells do a great job of hiding it. On the front end you can see a gap if you get up close and look, but you can buy gap guards if that bothers you.
Also, you don't even have to adjust the exhaust hangers, you can just loosen the bolts on the tips and pivot them up and it looks perfect.
Old 02-02-2012, 11:32 PM
hoyter hoyter is offline
Vehicle: '11 1500 sport 4x4
Trim Level: sport 4x4
Color: mineral grey
Rep:13
hoyter is on a distinguished road
Thanks Bug.
Time to spend some tax return money I guess.
Old 02-10-2012, 02:01 AM
5280RAM's Avatar
5280RAM 5280RAM is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:43
5280RAM is on a distinguished road
Anyone know where to get the bilsteins for the 2012 at a decent price? Or can I get a part number?
Old 02-10-2012, 08:11 PM
Kanuto's Avatar
Kanuto Kanuto is offline
Trim Level: Larime Longhorn
Kanuto is on a distinguished road
Keep in mind that if you cheap out and get a body lift it could creek and squeek after a few years as the suspention lift will not. The suspention lift will also keep your center of gravity better for off roading. Suspention is always the better way to go in the long run.
Old 02-10-2012, 08:15 PM
Kanuto's Avatar
I just purchased 5100 Bilsteins for my 2012 4x4, the model on the receipt is BS-24-187367.
Old 02-11-2012, 12:01 AM
5280RAM's Avatar
Color: Mineral Gray
Rep:43
Yeah..I think I'm going to go with Bilsteins to level it off first, then figure out where to go from there. The Bilsteins will be a bonus either way as I at least get the leveled look now and can use them in both a suspension or body lift later....
Thx....Where did you order from?
Old 02-11-2012, 07:37 PM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
If you have 3.9 gears and 18 inch or taller wheels go with the 4 inch lift. You will be so glad that you did when it's done. The ride will be much more balanced as the front shocks won't be preloaded higher than the rear, and the drive line will be all in the same as stock angles. Stance will be exactly level when you are complete.
If you have 3.55 gears as I do then go the body/shock route first. If nothing else you can use the shocks with the lift afterward on factory settings. Going 35 inch on 3.55 gears is going to kill the engine(in my opinion), and will have you pissed off and wanting to turn the MDS off as it won't hold well on highway at all.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 2/12" DC Level 3/Net Audio Sub Box, JL Components, ARC Audio Amps, Flowmaster American Thunder duals, Granite Alloys sporting 34" Falken Wildpeaks, HID conversion full blackout.
Old 02-12-2012, 01:04 AM
5280RAM's Avatar
Color: Mineral Gray
Rep:43
If you have 3.55 gears as I do then go the body/shock route first. If nothing else you can use the shocks with the lift afterward on factory settings. Going 35 inch on 3.55 hears is going to kill the engine(in my opinion), and will have you pissed off and wanting to turn the MDS off as it won't hold well on highway at all.
Thanks for the info...I just saw your other topic about your 5100 install. I thought that the bilsteins avoided the whole "death wobble" thing, but it sounds like thats not guaranteed.
Not sure what gears I have. I need to send the request to get the info...
What is MDS? Is that the Eco light that comes on??
Old 02-12-2012, 01:30 AM
Rep:27
If you have your sticker you can look and it will tell you what gears you have. The MDS is the engine going down to 4 cylinders when not pulling hard.
Death wobble is caused by driveshaft angle too great. Bilsteins and Level kits are equal culprits. Good thing about Bilsteins is they are adjustable. If you really think about the difference as far as driveline angle. 2 inches is 2 inches. Bilsteins put the two inches on the bottom of spring(move perch and make more shock body stick out under perch) and level kits put it on the top(move entire assembly down two inches with spacer). The strut seat to lower control arm bolt attachment is the same measurement with either so there is no difference as they will try and explain on the site. I just thought it would be worth going Bilstein instead of spacer as I like tad more progressive compression curve of aftermarket shocks and the can be used later with a lift if you decide to change it
Old 02-13-2012, 03:49 AM
5280RAM's Avatar
Color: Mineral Gray
Rep:43
Ahhh...maybe its best that I just save for the lift.
The sticker I have says:
2012 Ram 1500 SLT CREW CAB 4x4
Trans: 6-speed Automatic 65RFE
Electronic Shift on the Fly Part Time Transfer Case
Nothing about gearing...but I got the contact page in my bookmarks to get the build sheet.
