Old 02-17-2012, 12:50 AM
5280RAM's Avatar
5280RAM 5280RAM is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:43
5280RAM is on a distinguished road
Originally Posted by StoneyWV View Post
Wow, I am at a loss for words on that information Candy!.
5280RAM; Sorry for thread jacking, let us know what you decide and how it turns out
I don't mind...I'm just trying to soak up all the info since I'm new to all this lifting and truck stuff
I will prob just level it out with Bilsteins since there isn't to many 4" lifts available for the 12's yet and it not quite in the budget right now
Old 02-17-2012, 12:55 AM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
Depends on manufacturer of lift and backspacing on your current stock wheels. You can simply download the instructions that come with the lift you are looking at from the manufacturers website, or call them up and ask. If you have 17 or 18 inch wheels some of the lifts we have installed call for maximum backspacing of 4.5 inches on 17. I believe the Rancho is best case and you can use 17 inch steel rims, and Zone is worst case. Calls for 4.5 inch max backspacing on 17 inch rims so you can't use factory 17 steel wheels. Not sure the backspacing on all the 18 and 20 rims from Dodge you would have to measure yours and verify what they are.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 12" Dayton/Net Audio Sub, JL Components, ARC Audio Amps, Magnaflow 14 inch, Granite Alloys sporting 34" BFG T/A KO, HID conversion full blackout.
Old 02-17-2012, 01:12 AM
Dodge891's Avatar
Dodge891 Dodge891 is offline
Vehicle: 2001 dodge ram
Trim Level: Single cab short bed
Color: Vader Black
Rep:48
Dodge891 is on a distinguished road
I agree that makes such a big difference on looks
Sparky says RAM IT
Old 02-17-2012, 02:19 AM
Rep:27
Yea, I try to be a realist and if you aren't willing to spend 3 grand on lift w/install, new tire/wheels then probably best to level and upgrade rubber a bit little taller more aggressive and call it a day. Helps to be able to do everything yourself, but average folks don't have all the tooling required to install a full suspension lift in their garage. Let's see some pics when your done.
Old 03-05-2012, 06:44 PM
maximus007's Avatar
maximus007 maximus007 is offline
Vehicle: 2010 Ram Crew Cab
Color: Light graystone metallic
Rep:12
maximus007 is on a distinguished road
Originally Posted by Bugaboo232 View Post
]I went with Bilsteins and a 1.25 inch body lift and love the stance with 35s, It's basically the same look as the 4 inch suspension lift but significantly cheaper. It's only about 300-350 in parts and it's easy to install yourself with the proper tools. Sorry for the crappy quality pic, just plastidipped my rims and snapped this before work today.
You didn't do nothing in the rear? did you have to run wheel spacers on the front?
Bilsteins set at 2.8, rcx1.25 bodylift,fuel krank wheels with 35in toyo at 2s, tinted windows, K&N drop in,14" Magnaflow muffler, Diablo Trinity 1000 hemifever tuned, airlift 1000s, 2500 fender flares color matched, spray in bed liner, moroso catch can, 180 t-stat
Old 03-11-2012, 01:52 PM
maximus007's Avatar
Rep:12
I just went bilsteins in the front set at 2.8 and the body lift is rough country(rcx).
Do you have any vibrations or wobble with them set at 2.8? I'm going with the same setup on a 2010 crew cab
Old 03-18-2012, 12:52 PM
tcat115 tcat115 is offline
Vehicle: 2011 Dodge Ram ST
Color: RED
tcat115 is on a distinguished road
Hi, could a guy just go with the Billsteins on the front to level a 4th Gen. I have a 2011 Ram ST.
Thanks.
Old 03-18-2012, 06:39 PM
shostopper17's Avatar
shostopper17 shostopper17 is offline
Vehicle: 2011 Dodge Ram Express
Trim Level: 1500 Express
Rep:54
shostopper17 will become famous soon enough
Just go 6 inches and call it a day lol
