Old 02-02-2012, 03:16 PM
03lowram 03lowram is offline
Vehicle: 2011
Trim Level: Badass
Rep:19
03lowram is on a distinguished road
Originally Posted by moparornocar72 View Post
Yeah i'm going to just wait it out! Just got first weeks pay and it will def. come sooner to save. by then there may be some more options available also!
Good choice!!!
Old 02-02-2012, 03:29 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Get your tax return yet? That should be enough to get ARH's!
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 02-02-2012, 09:55 PM
moparornocar72's Avatar
Rep:630
I'm putting some of it in savings, then the rest in my 73 dart sport 340 i'm restoring! I thought about it though!
14.268 @ 95 MPH Full Trim
Old 02-02-2012, 09:57 PM
Rep:630
recieved an email back about lt's from pacesetter:
Thank you for your interest in Pacesetter Performance Products.
We have some Vehicles set up for testing but it maybe beginning of Summer before we have any updates available. Check back with us in about 3 months or so.
Thank you,
Pacesetter Sales Team
602-266-1964 x505
Old 02-03-2012, 09:59 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
why not get the SRT LTs and try them and if they dont work return em? The only place a header install is tight is the drivers side around the steering knuckle (mine rubs ) the passanger side is a breeze though. In all reality all you need is the headers themselves to clear everything, any semi competent exhaust shop could fab you a y set up or a dual setup from the collector.
2011 Big Horn 4x4 -SnowWhite-
Old 02-03-2012, 03:24 PM
Rep:630
Im going to keep my cats, although we dont have emissions test in AL if u get pulled over for anything and they look and see no cats its a major fine. My plan now is to save up dilegently until i can afford 2 sets that way some can go towards a ring for my girl down the road and etc. In the mean time i'm waiting on some other options to become available, thanks everyone for all the help and if any new info becomes available let me know!
Old 02-05-2012, 05:21 PM
P-Rez's Avatar
P-Rez P-Rez is offline
Rep:28
P-Rez is on a distinguished road
what comes over the mind to look for no cats really??
P-Rez
Old 02-05-2012, 05:30 PM
Rep:630
Greedy APD cops! They just recently got off an investigation by the FBI. Two higher ups went to jail for fixing tickets and i believe aiding in a betting. Also they just passed a sound ordnance so if u have loud exhaust, they look for cats and mufflers.
Old 02-05-2012, 06:58 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
cant find pacesetter lt's? i bought a used set 5 years ago and have run them over 150k miles..gotem for less than $200
edit..just saw you were asking them about it...
Old 02-05-2012, 09:19 PM
Longhorn2011 Longhorn2011 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Laramie Longhorn
Color: White/White Gold
Longhorn2011 is on a distinguished road
Installed my JBA Headers. Jacked up the front and put it on jack stands. Removed front wheels and wheel well liners and unbolted the steering shaft. I did most of the install sitting on a stool. It took about 4 1/2 hrs by myself. Knowing which tools I need and what to do I think I could do it in 2 hrs now. I had to bend the dipstick tube a little to reinstall it and keep it from touching the header. On the passenger side install the gasket with the top second bolt from the rear (if you don't you will cross thread it, trust me on this. Luckily I was able tap the threads). The header flange is slotted so you can slip the header onto the bolt then you can install another bolt to help hold the header. It would help to have another person helping. The drivers side flange is slotted for all the lower bolts so you can install the gasket and lower bolts and slip the header onto the lower bolts. I didn't use any of the mounting hardware that came with the headers. I used Stage 8 Header Bolts and factory manifold gaskets. There were supposed to be some stand-offs to raise the heater hoses up a little further from the header but they were not in the box so I'll have to contact JBA, but I don't think they are really needed. I didn't disconnect the y-pipe since I don't have one as I have true duels. I just unbolted the exhaust from the manifold and pushed the exhaust back as far as I could and it was fine since I installed the headers from the fender well.
