Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 01-30-2012, 05:02 PM
Skip235 Skip235 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Blue
Skip235 is on a distinguished road
Default Tire Rod/ Wheel Bearing issue
Ok, so I got the tire rod recall done on my truck. Cost me nothing except a new set of tires. Now less than 2k miles later they are telling me my wheel bearing is bad. The question is, has anyone else had a problem with their wheel bearings after they had the tire rod recall done on their truck. I find it hard to believe that my 36k truck already has a bad wheel bearing (conveniently after the warranty expired). Plus they are saying it is like $450 to get this done. Does that seem strange to anyone else? thanks in advance for any input.
Skip
Old 01-30-2012, 05:55 PM
Rep:2705
before my warranty expired, i bought the Lifetime Maximum Care Warranty, but with the $100 deductible, i would still have some cost
When they replaced the TIE ROD, they should have checked out the complete steering & suspension, as well as doing an front end alignment
If they told you that it needs a wheel bearing, i don't see where it would cost that much
you could buy the best Timkin wheel bearing & hub assembly for $187.15 + tax
(believe me, Dodge uses a much cheaper part than Timkin)
http://www.am-autoparts.com/2009/Dod...71/561294.html
If you only need the wheel bearing, you would only need it & the wheel bearing seals.
Not the whole hub assembly
Personally, i would take the Ram to a Alignment Shop & get the work done, or at least have them inspect it
Old 01-30-2012, 06:58 PM
Color: Blue
Thanks for the fast reply. I'll take it to a alignment shop!
