Old 01-30-2012, 07:32 PM
dakota1820 dakota1820 is offline
Vehicle: 97 dodge ram
dakota1820 is on a distinguished road
Default 97 46re tramny acting up what should i do?
My buddies 97 ram 318 2wd has been having a little issue. When cold outside around. Freezing if he just jumps in And take off when he gets to the top of the hill and stops and then goes again it'll slip. It revs for 2 seconds or so then goes. After that it wont do it. Only when its stone cold . What would cause this? Filter has about 15k and flush was done with bg universal atf . The fluid says it is specd for atf3 and 4 . The fluid looks good it goes into each gear with no delay or issue.. someone help thanks guys..
Old 02-01-2012, 06:25 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
New (correct) fluid-not universal, filter, band adjustment, replace anti-drainback valve in fluid return line. Make sure it's filled to the proper level. Sounds like it's low or restricted and needs time to warm up (oil expansion) to get the job done.
