Need some help yet again - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 01-30-2012, 11:32 PM
safet3rd safet3rd is offline
Vehicle: 1998 Dodge Ram 1500
safet3rd is on a distinguished road
Default Need some help yet again
Okay well a few of you might remember my previous post, I kept getting misfire codes after replacing the plenum...........Well i now have changed everything possible, put new plugs and wires and all that, seafoamed it, new injectors, new cat etc....
Well yesterday I was drivng and the CEL came on yet again cant remember the code but it was for a fuel pump relay......i bought a new one and replaced it.....now today im getting code P1282 which is for Fuel air metering?? and now 8 misfire and 6 misfire......
I just bought this truck and once i think all codes are gone i get a new one mixed with an old one then it runs good for 2 days then another new code mixed with the same codes i have been getting which are the misfires....at a loss of what to do with this damn thing.
Old 01-31-2012, 12:30 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Thinking out loud......
This could well be a wiring connection or ground problem. Most likely culprit that affects all of these items is the PCM. Have removed the PCM connectors and checked for corrosion. Sometimes the physical act of removing and re-installing the connectors (which cycles the contacts) can reduce/eliminate these issues. Make sure the battery is disconnected before puling off the PCM connectors.
brad
Interested in one of my mods?
Old 01-31-2012, 11:32 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I dread the #8 misfire code. On my wheels, it has ALWAYS indicated a vacuum leak, is it possible that theres a hose off? Seeing as how you've done the plenum thing...
Old 02-04-2012, 08:52 AM
Brutus's Avatar
Brutus Brutus is offline
Vehicle: 2006 Dodge Ram
Trim Level: 4x4 Quad Cab Sport
Color: Mineral Gray
Rep:86
Brutus will become famous soon enough
yeah, i'd say to climb back under the hood. make sure everything is hooked back up. check to see if your vacuum lines are cracked towards the ends. all grounds are connected. check for any pinched wires.
i can't imagine that a plenum fix would cause you to replace some of these parts that you are replacing.
2006 Hemi Ram QC 4x4
2000 AF RC Dak R/T
2000 BW CC Dak R/T
