Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 01-31-2012, 12:21 AM
SawdustJ's Avatar
SawdustJ SawdustJ is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:22
SawdustJ is on a distinguished road
Default Stock Brakes on the 2010 Underpowered
Hi gang,
First post.... my 2010 is my daily driver / work truck. The brakes, to me, seem underpowered. My '08 before this one was more or less the same. I'm at the point now where I need to replace my front brakes. I'm not keen to replace with originals an am considering upgrading to something more performance or heavier duty oriented.
Can anyone make any suggestions or perhaps share their experiences if they've gone down this path?
Much appreciated.
JJ
Mods: Extang Tri-fold Soft Tonneau Cover, Bed Liner, Volant CAI
Last edited by SawdustJ; 01-31-2012 at 12:23 AM. Reason: Just fixing some punctuation
Old 01-31-2012, 12:56 AM
Rambunkshuss's Avatar
Rambunkshuss Rambunkshuss is offline
Vehicle: 2014 Dodge Ram
Rep:87
Rambunkshuss will become famous soon enough
Drilled rotors & Hawk ceramic pads
Life`s tough, its even tougher if you`re stupid
Old 01-31-2012, 02:14 AM
Rep:2620
you might look at a company that sells at local auto parts stores like PEP BOYS
great brakes &rotors
http://www.ebcbrakes.com/
Old 01-31-2012, 08:53 AM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
Wow, so far I'm very impressed with my 2010's brakes. Pedal feel seems real good to me and it doesn't take much pedal pressure to get it slowing up in a hurry.
Old 01-31-2012, 05:40 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^I agree, the 3rd and 4th gen rams have the best braking capability of any full size light duty truck. The fact that you are due for brakes alone is probably half the issue. A good set of pads is about all you can do, drilled or slotted rotors help a little.
Sean
Old 02-01-2012, 01:17 AM
SawdustJ's Avatar
Rep:22
Hi everyone,
My truck is not a leisure vehicle or the grocery runner, that's what the wife's minivan is for.... My truck gets worked and routinely carries payloads ranging from a couple hundred pounds to a thousand pounds. Perhaps this is one of the reaons I feel the stock brakes aren't cutting it.
Besides the obvious, what's the difference between slotted and drilled rotors? Is one better than the other?
Thanks.
Old 02-01-2012, 05:21 AM
blk2011st blk2011st is offline
Vehicle: 2011 Ram
blk2011st is on a distinguished road
Originally Posted by SawdustJ View Post
Hi everyone,
Thanks.
It is mainly for venting and dispersing heat. I wouldnt call one better than the other. You can get drilled rotors, slotted rotors, or drilled AND slotted rotors. I personally dont like drilled rotors because of previous experiences on my mustang where they would get small cracks in between the holes after several good heat cycles. I love the ebc DIMPLED and slotted rotors. I plan on getting some for my ram with some ebc "green stuff" pads when the time comes.
Old 02-01-2012, 08:56 AM
snrusnak's Avatar
Rep:1385
I remember seeing an article about drilled vs. slotted and one was deemed better than the other, because it was less likely to warp and crack, and had more contact surface area....I just can't remember which one it was now though lol.
If I'm not mistaken also there are some "big brake kits" out there.
Sean
Old 02-01-2012, 11:39 PM
storeboy storeboy is offline
Vehicle: 2009 Dodge Ram
Rep:19
storeboy is on a distinguished road
Go for some dimple and slotted rotors and some EBC brake pads (I have heard green or yellow work the best). Doing both of these will make a huge difference in your braking.
The difference between drilled and dimpled rotors are that drilled are just that, they are drilled all the way through. They are a lot more prone to cracking and warping (especially if you drive through a lot of puddles). Dimpled rotors just have little dots, but don't go all the way through (about the same depth as the slots). Since they are not drilled all the way through they tend to hold up better to warping while at the same time help to dissipate heat.
Old 02-02-2012, 12:18 AM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
Between drilled and slotted, I have had much better luck with slotted. The cheaper, non big brake, drilled rotors can crack and warp. I've had two sets on other vehicles and neither lasted more that two sets of pads. The slotted rotors performed better for me and were much more durable.
A drilled or drilled and slotted big brake set from companies like Baer or Brembo is where you are going to see the big improvements.
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
