Old 02-04-2012, 08:45 PM
SilverSport2011's Avatar
SilverSport2011 SilverSport2011 is offline
Vehicle: 2012 Ram Sport 4x4 Crew
Color: Mineral Gray
SilverSport2011 is on a distinguished road
I have a 2011 with the hemi I went with the full deal on the K&N. I got the Air Induction System and it has made a big difference in power and sound. When you punch it almost sounds like a turbo kicking in. According to K&N it gives your truck a 15.66 Hp gain also it was easy to install only took about an hour went by the video on youtube!
Old 02-04-2012, 09:37 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
True story. I picked one of these up last summer! I just switched to a Vararam. I have the K&N filter if you wanna take it off my hands..
[CENTER][SIGPIC][/SIGPIC]
Old 02-05-2012, 09:25 AM
macked macked is offline
Vehicle: 2011 Ram 1500
Rep:17
macked is on a distinguished road
I read this article on Bob is the Oil Guy : http://www.bobistheoilguy.com/airfilter/airtest1.htm
Basically when they say the performance filters filter as good as paper, they're lying.
Old 02-05-2012, 11:40 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Paper filters filter the best I believe, then foam (although foam may be the best, I can't remember) the worst is the types like K&N, etc...
But realistically, they trap most of everything, they won't let anything in that's big enough to do damage. Who cares if particles 50 times smaller than dust get in your engine, you know? It's the sand and larger stuff like that that can score cylinder walls...
Sean
Old 02-06-2012, 07:52 AM
MD11's Avatar
MD11 MD11 is offline
Color: Mineral Gray Metallic
MD11 is on a distinguished road
You will get all sorts of "internet experts" telling you that K&N filters aren't as good as a paper filter. I have used them in all my cars for the last 12 years. My oil is NEVER gritty, no MAF issues (on my Corvette & Z28) and in my 5.7 Hemi, I actually got an increase of 2-3 MPG.
K&N has videos showing how to properly oil them. People that see problems while using K&N filters erroneously attribute their problems to an air filter.
Just change your oil and take care of your vehicle and K&N filters will do just as they're supposed to: increase air and offer all the filtering that you'll ever need.
Old 02-06-2012, 09:08 AM
anoldbiker anoldbiker is offline
Vehicle: 2006 Dodge Ram Quad Cab
Trim Level: SLT Big Horn
anoldbiker is on a distinguished road
There are 2 things you should consider.
1. Get a pre-filter if your going for an oil filter. This just helps keep the big cr%p off the filter and makes it easier between cleanings if your on the road and get in a very dirty climate. I had a filter full of trash just traveling Hwy 40 through OK, TX, NM and part of AZ when Mexico was on fire and the farmers were plowing for planting. The pre-filter had to be cleaned with a quick rinse and re-installed with the rest of the trip being without issue.
2. DO NOT over oil when you clean and re-install the filter. Many do that, an that's when you get oil after the air box giving you problems. Oil the filter enough to coat the material only. Your not doing an engine oil change. A 1.4 can is not needed.
I've ran K&N filters for years without issues. The last gasser I had was using a K&N and when I gave it to the neighbor kid when I retired, it has 400k on the clock with the same K&N. He is still using it. The only reason I don't have s K&N in this truck is I wanted as true a CAI as possible when I bought her. My wife's pickup has a K&N and it will be there until it leaves the family.
I agree with the above comment. If you have 50 people owning air filters, you'll have 50 different views / beliefs.
You will NOT get lots of extra horse power with them, but they work. On my diesel, with the stock air filter, I use to have a large soot spot on the right rear panel in 1k. Just with the filter change alone, I had way less soot in a 5k vacation run. I did get more air. Yet, when many people say it throughs oil down your intake tube after the filter, (watching how you properly oil after cleaning), I have NO oil or dust on my sensors, tube or turbo.
You'll be fine
