Shocks no good? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Suspension
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 01-31-2012, 05:15 PM
NWTJetboater's Avatar
NWTJetboater NWTJetboater is offline
Vehicle: 2009 Dodge Ram
Trim Level: Fully Loaded
NWTJetboater is on a distinguished road
Default Shocks no good?
Have my truck at the shop right now fixing some heat issues and asked them to look at the shocks as every bump I hit they bottom out hard..especially when it is below -15C...dealer says they are fine..seals not leaking etc...now this is my 5th dodge ram and also have 3 at work all half tons..mine which is the nicest of all of them rides the worst because of the constant bottoming out..they wanted to give it back but I requested they check again(another test drive) as I will not be happy unless they change them....any ideas on how I can convince them they are shot ? I feel like something is going to break if I hit a bump over 40KM/hr..
"If you ain't hitting bottom, you ain't jetboatin !"
Old 02-01-2012, 04:23 PM
keala's Avatar
keala keala is offline
keala is on a distinguished road
The real question is, did they actually remove them and check or did they just do a visual? Is your truck 2wd or 4wd? 2wd drive is too easy to unbolt and check. 4wd on the other hand, is a totally different story. How many miles on your truck?
2009 dodge ram laramie 2wd
Old 02-01-2012, 05:36 PM
Truck is 4WD with around 45000 miles. I bought it at 35. It wasn't till this winter it started to bottom out.
When I talked to service they said the mech took it for a quick spin and did a visual..then did the update to the heater unit and called me to PU. I asked them about the shocks and they said maybe I had too much snow in the box..I kinda laughed and said "shouldn't I be able to put a skidoo or quad in there and head down the highway without bottoming out on every bump..never mind 5 shovels of snow?" Service told the mech and I could here him say..well hes got a point ill take it for another drive and look again. They are changing the springs for now and will see if that helps or eliminates the bottoming out.
It is a bit frustrating that I now have the nicest truck I have ever owned...Hemi Power 4x4 on the fly...but on our ruff roads it doesn't ride that well.
Last edited by NWTJetboater; 02-01-2012 at 05:37 PM. Reason: pasting error-hands are frozen
Old 02-02-2012, 03:54 AM
keala's Avatar
I don't think its yours springs. The shocks may just be bad. Maybe weather and roads just made them go bad at 45,000 miles. Just use this as an excuse to get some bilsteins adjustables and level your front end. Lol. These will be new shocks and you can adjust the spring perch up to 2.8" in height increase. I would stick with 2.1" since you use 4wd more than the average person. Also, check your front bumpstops and see if they are in good shape too. Aloha
Old 02-02-2012, 04:36 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default Not sure if its the shocks...but we have the fix
NWTJ,
Of course, don't know if its your shocks, but we have the fix for you.
Total Load Control™ Suspension is the revolutionary air suspension that will keep your truck level with any legal load. And TLC improves steering, handling, braking and ride loaded or unloaded.
TLC consists of 2 9" Goodyear Dual Convolute Air Springs that easily mount without any modification to your suspension.
Here is what Z Member Goldviper posted:
"Hello All,
I installed the TLC Suspension on my 2012 Ram Laramie 4x4 last weekend and I am really please with the results. No more SAG. I will be carrying a RZR S in the bed of the truck and the air bags will keep the truck level. I pull a trailer now and they really work."
Please check us out at the Z Vendor Forum or TotalLoadControl.com
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Last edited by TLC John; 02-02-2012 at 04:40 PM. Reason: Make addition and punctuation
Old 02-02-2012, 05:59 PM
How will the air bags perform at -30 and colder??
Old 02-02-2012, 08:02 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
Originally Posted by TLC John View Post
NWTJ,
"Hello All,
John, his problem is in the front, not the rear. do you sell leveling bags for front ends as well?
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 02-02-2012, 09:08 PM
TLC John's Avatar
Rep:17
Default -67 F & Thx Army of One, You're Right
The Goodyear Air Springs we use are rated to work down to -67 F.
Thx Army of Oone - I didn't see that its a front end issue.
We are working on TLC systems for lifted/leveled trucks; not available yet.
Total Load Control™
Old 02-02-2012, 09:23 PM
ArmyofOne's Avatar
US Army Retired
Rep:1230
Hey no big deal bud, believe me if you made leveling bags for the front, I would be ALL OVER IT
Old 02-03-2012, 12:43 PM
I think its the rear shocks that have gone ..why do you say the front
