Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 01-31-2012, 07:42 PM
Idrivemav Idrivemav is offline
Vehicle: 2012 ram 1500
Idrivemav is on a distinguished road
Default Wheel hop
My truck has som wheel hop whenever I spin it will spin good at first but when it starts to hook it starts hopping the suspension wheels and tires are all stock how do I get rid of it
Old 02-01-2012, 12:34 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Im assuming that this is a rear wheel drive truck and you may want to try and just walk it out of the whole. Not knowing what performance mods you have i cant really tell you what to do. I think that you should be fine if you have the big 3. I cant say i have ever heard of wheel hop on this forum being an issue with or without mods but hey you never know.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 02-01-2012, 02:32 AM
All my truck has done is a cai and muffler delete it's a 2012 single cab express I'm probably goin to lower it in the next few weeks
Old 02-01-2012, 06:46 AM
2011lilred's Avatar
2011lilred 2011lilred is offline
Vehicle: 2011 1500 & 2006 2500
Trim Level: Express &ThunderRoad
Color: Flame Red & White
Rep:15
2011lilred is on a distinguished road
I don't think anyone else has reported wheel hop issues with the 4th gen control arm suspension setup, are you sure it's not the traction control cycling in and out? If it is true wheel hop, lowering it may make it worse, as lowering a control arm rear suspension affects the geometry and changes the instant center. To eliminate wheel hop, the goal is to drive the rear tires down into the ground, thus planting the tires harder. If you look at a 64-72 Chevelle rear suspension, which is functionally the same as the 4th gen Ram setup, drag racers use either "no-hop" bars on the uppper control arms, which raise the pick-up point at the axle for the upper bar and/or relocated lower control arm mounts which lower the pick up point at the axle for the lower bar. This this is also the whole design intent of Cal-Tracs bars for leaf spring cars and the old South Side Machine bars for both leaf springs and control arms. Some folks will talk about "squat", but this is counter-productive as "squat" is actual a result of the rear suspension drawing the tires up into the body and unloading the tires, so while a car that "squats" off the line looks like it's good for weight transfer, it is not - watch a Super Stock car someday, not only the Mopars, but even the rear of the fast Ford and Chevy cars lift up on launch. If you lower your 4th gen, the upper control arm will get a better angle, but the lower control arm will get a worse angle. This may or may not make the wheel hop even worse. I don't know of anyone making a lower control arm relocation bracket for the 4th gen Rams yet, but one for a 94-96 Impala SS looks really close and might work or be adaptable. I considered trying one, but I haven't had any traction problems so at this point it would be moot, I just need more gear - I've cut 2.175 60ft times on the stock 20s with 3.55 gears. Good luck.
RIP - 03 Hemi SLT QC; uncorrected 14.68 at 90.46 w/ 2.08 60ft - stolen July 06
Old 02-01-2012, 08:36 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I'm surprised to hear about wheel hop in a 4th gen...3rd gens yes with the old leaf spring setup...
Old 02-01-2012, 08:41 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Yeah I wouldn't expect wheel hop with the 4th gens and the coil springs and "5 link" and all....kind of strange. Mine has no wheel hop (although only one wheel spins....)
Sean
Old 02-03-2012, 01:30 PM
ram71351's Avatar
ram71351 ram71351 is offline
Vehicle: 2014 Dodge Ram Laramie
Color: Black Gold Pearl
Rep:45
ram71351 is on a distinguished road
Idrivemav is correct, I have experienced wheel hop several times myself. I was also told to move my lower control arm more to the back to eliminate it. Haven't done it yet. Looking for a kit to come out hopefully.
Old 02-03-2012, 01:32 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
I have yet to exp this and i have already been through a set of tires lol
Old 02-03-2012, 02:42 PM
snrusnak's Avatar
Rep:1385
What are you guys refering to when you say "lower control arm"?
Sean
Old 02-03-2012, 05:15 PM
incubus868's Avatar
incubus868 incubus868 is offline
Vehicle: 2014 Ram
Trim Level: Larimie
Color: True Blue
incubus868 is on a distinguished road
I have the same problem open rear end 3.55 if I floor it around 50 mph when it drops to second my back end starts hopping and it is actually hopping because I can feel the back of the truck kicking off to the side it is not a problem at lower speeds though
