Old 01-31-2012, 09:00 PM
studda studda is offline
Vehicle: 2001 Dodge Ram Sport
studda is on a distinguished road
Default Sputtering/missing problems
I bought a 2001 Ram from my step dad. It had been sitting for about a year with no battery in it. It ran fine when he parked it. Now, it misses, sputters, and sometimes pops when the motor is loaded. I changed spark plugs and wires but nothing changed. Also, it won't run at all hardly if it isn't completely warmed up. I do have a check engine light but that's for a neutral starting switch. That wouldn't affect it would it? Also, the truck only has 75k miles.
Old 02-01-2012, 12:35 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
sitting for a year? needs a major tuneup...
Old 02-01-2012, 12:36 AM
chefred112's Avatar
Rep:656
what was the specific code that the mil light showed..
Old 02-01-2012, 02:27 AM
wstimpson wstimpson is offline
Vehicle: 1998 Dodge Ram
wstimpson is on a distinguished road
A year is a long time for a vehicle to sit not running like chefred said a complete tune up wires and plugs aren't gonna help much if you haven't changed the distributor cap and rotary button if changing those 2 doesn't help change all the fluids and filters including those in the fuel system gasoline can eat up a lot in a year
Old 02-01-2012, 11:55 AM
The gas is all good now. I ran most of the gas out, dumped in some seafoam, and filled it up with high octane. It runs fine at idle and WOT. Just when the RPM's are midrange with the motor loaded(climbing a hill or accelerating), it does this. Also, it's worse when it's cold. I'll try a cap and rotor to see if that helps.
Old 02-01-2012, 09:05 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Try resetting the ECM and don't check the codes with the K3 technique. Disconnect the battery, turn the key to start, and then re-hook the battery. Take it for a ride and get back to us.
Old 02-01-2012, 09:54 PM
Changed cap and rotor. No dice. What is the K3 technique? I will try resetting the ECM. Do I leave the key on when I connect the battery again?
Old 02-01-2012, 09:57 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
General tune up, sensors, and intake plenum gasket.
Old 02-01-2012, 11:03 PM
I reset the computer and it did increase overall performance. It did not fix my problem though. It seems to run the same cold as warm now. I guess I'll find out tomorrow though. Sometimes, it runs better than other times.
Old 02-01-2012, 11:09 PM
Vehicle: 95
Rep:1776
Unplug #1 injector and see if it gets worse or stays the same. If it stays the same it's #1. If not try #2. Both are at the end of the fuel rail and have a tendency to get clogged as they are at the ends of the rail (front of engine) and can cause symptoms like you're explaining.
