Old 01-31-2012, 10:05 PM
neonarc neonarc is offline
Vehicle: 2007 Dodge Ram 1500 QC 4x4
Color: Inferno Red Crystal Pearl Coat
Rep:20
neonarc is on a distinguished road
Default Steering Wheel Column Noise
Hey everyone,
I have a 2007 Dodge Ram 1500 4x4 Steering Column Noise that I just bought with 48k miles on it. Since I bought it it's been making a clicking scraping noise in the steering column just behind the steering wheel.
It only does this when the wheel is moved side to side or over rough pavement such as cobble stone. It even does it with the truck stopped and the engine off.
Today I decided to take a look so I removed the shrouds and moved the wheel side to side to replicate the noise. I felt the clockspring assembly just behind the wheel, the multifunction switch and also the intermediate shaft as I moved the wheel. The only part I could "feel" the noise thru was the multifunction switch. No other part would even slightly move or have any vibration felt thru it when doing this.
Video of Noise
So now I am planning on replacing the multifunction switch but first I have 2 questions. 1, is there anything below the switch that can be making the noise and not be felt on the shaft? 2, Is it possible to remove the switch without removing the wheel and clockspring?
I searched but did not find anything definitive on this.
Old 02-01-2012, 10:26 PM
Rep:20
So ive been looking around and reading the service manual and i feel confident i can remove and replace the multifunction switch myself. i can get a loaner steering wheel puller from the parts store.
However, after looking some more at the switch, i think it may be possible to remove it without removing the wheel. I will give it a try this weekend.
the parts store has the switch for nearly half the price as the dealer and it looks identical to the stock piece on the outside. I'm only worried that it won't have the tap turn signal that makes it blink only 3 times.
Old 02-13-2012, 06:26 PM
ramoreno's Avatar
ramoreno ramoreno is offline
Vehicle: 2002 Dodge Ram
ramoreno is on a distinguished road
hey como te fue?
i see a clock spring removal guide over here in somewhere i dont know if you neeed but...
http://www.ramforumz.com/showthread....ghlight=airbag maybe you all ready do this job.
Old 02-13-2012, 06:40 PM
Rep:20
Todavia no la quito.
I have not found a way to get a screw/torx in there without removing the steering wheel.
I have been busy, I changed the condenser fan motor, I repaired a window motor and some door rattles. Next on the list are spark plugs and oil change. Hopefully this long weekend I will have time.
Saludos,
Old 02-13-2012, 06:48 PM
Be careful and read up on disarming the airbag before removing the steering wheeel .
