Old 02-01-2012, 09:58 PM
chrisman183 chrisman183 is offline
Vehicle: 01 ram 1500
chrisman183 is on a distinguished road
Default Severe shake/miss ?
Hey guys, my 2001 is acting really bad. When I'm driving, and only partial throttle, motor will shake like a son-of-a-b, especially around 40-55 mph. i'm sure its the engine causing this, i can somewhat feel it even when the truck is parked, and i give it just a little gas. the thing is, at idle it doesn't shake, and at full throttle it doesn't shake, or i can't tell, and when I'm driving at let off the gas it stops shaking immediately. I changed plugs/wires/rotor/cap. Any ideas? I was thinking maybe injector? or fuel pump or something. please help, kinda scared to drive it, the shaking is pretty bad. No engine light on.
Old 02-01-2012, 10:34 PM
studda studda is offline
Vehicle: 2001 Dodge Ram Sport
studda is on a distinguished road
Does it pop and sputter? Mine shakes too. It kinda lunges repeatedly, misses, and sputters until I let off the gas or go to wide open throttle. If that sounds like yours, I'm trying to figure it out myself.
Old 02-01-2012, 10:41 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Sounds to me like a bad clutch on the cooling fan. Get under the hood with it off and try spinning the fan. I'm almost willing to bet that it's locked up tighter'n a clams wallet.
Either that or it's on it's way out and spinning intermittently. It'll throw the whole balance off the engine and drive you nuts...you're probably thinking...Hmm now that he mentioned it...
Oh and Welcome to the Forum!
Old 02-02-2012, 09:46 AM
ha, thanks a lot warlokIII, i'll go check that in a minute. should it be easy to tell if it's the fan? if it is able to spin now with it off? how would i know exactly?
as for the popping and sputtering studda, its hard to tell really, it isn't doing that very loud, but when its shaking like that, it does make it sputter, it seems, but that may be just the weight shifting back and forth, causing a little lunging. I saw your post on here, but thought mine sounded a little different, i wasn't sure if I should just post a new thread or post on yours. but maybe we can help eachother out, maybe it is the same thing. its impossible to relate exactly how something feels/sounds on here...
Old 02-02-2012, 09:52 AM
Vehicle: 95
Rep:1776
There should be some resistance in the fan when you spin it, it should be smooth.
If it's cold it may seem okay, so it it does try it again when it's warmed up. It's controlled by the engine heat that monitors it to engage and over time the oil inside of the clutch can escape or go bad. As for the popping, that's usually one of the side effects of the engine being unbalanced.
Think about those old black and white movies of helicopters when the rotor is unbalanced and the whole aircraft flies apart.
Old 02-02-2012, 02:19 PM
hmm, seems like the fan is ok to me. checked it out when it was off, and when engine was hot. seems fine. more details, it seems to be bogged down real bad, the engine, it is the worst right after the shift into overdrive. right when the rpms are at the lowest, and you are just barely on the gas. engine shakes like crazy. almost like a tire is loose, thats how its shaking. as soon as you let off the gas, its smooth. and if you give it over 50% throttle its also smooth. the miss isnt too noticeable at idle, wires are correct, and firing on all cylinders. bought some techron stuff. doubt that does anything.
Old 02-02-2012, 05:41 PM
Vehicle: 95
Rep:1776
I'm still leaning towards fan clutch. Any way to get a camera to stay under there and video it?
Old 02-02-2012, 06:36 PM
DTA47 DTA47 is offline
Vehicle: 1995 Dodge Ram
DTA47 is on a distinguished road
Mine has the same issue I'm waiting on parts now. But for me it ended up being the Sway bar link bushings, they were completely shot. Hope this helps.
Old 02-02-2012, 10:55 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I'd have a look down the intake with a flashlight, with the throttle plates wide open, to see if it 's oily inside the intake. Low rpm miss, most noticeable under load, runs good with high rpm, with motor mashed, with my 98, it was a vacuum leak, but I was lucky, it was those axle disconnect tubes off, down on the drivers side of the crossmember, it also wouldn't connect the 4x4 at the axle disconnect, apparently, if you have a vac lk, it isn't the same one I had...
Old 02-05-2012, 07:19 PM
macez's Avatar
macez macez is offline
Vehicle: 1998 dodge ram 1500
Trim Level: st
macez is on a distinguished road
my 98 was doing the same thing but it was throwing codes and it turned out to be the downstream o2 sensor.
engine miss, shaking
