Ram puddle light defect (Mods Sticky this for all 4th gens) - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 12-09-2012, 09:36 PM
Grubrunner's Avatar
Rep:3883
Originally Posted by OMALLEY808 View Post
Just want to let everyone know that the 4th gen puddle lights are not properly sealed from the factory and will become water logged and corrode. Both left and right on my truck are corroded already.
I just picked up another puddle light from a 2011 and you can visibly see the two halves are not properly sealed and it had some water in the unit.
YOU CANNOT BUY JUST THE PUDDLE LIGHTS FROM DODGE
(You must buy the entire mirror assembly)
**save yourself time and money and reseal yours with some silicone!**
Thanks for the heads-up, though I've had zero problems with mine.
Question: How exactly does plastic "corrode?" I always thought metalalic materials corrode due to a chemical reaction with the enviroment.
Never heard of plastic corroding.....
Grub out!
Old 01-01-2013, 11:10 PM
Torquie1 Torquie1 is offline
Vehicle: 2009 Ram 1500 Sport
Torquie1 is on a distinguished road
Default Puddle Lamp
Despite popular belief you can buy the puddle lamp without the entire mirror. Part number 68087235AA. They are also available on ebay or Mopar Online.
Old 02-02-2013, 03:39 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
Dealer replaced both of mine when they went out completely.
Will have to look at sealing them before the warranty is up...........
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 02-02-2013, 07:03 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1260
I live in western WA, it rains here CONSTANTLY. 300 days+ a year, its raining.
I have ZERO water in my 2011 puddle lights.
My headlights on the other hand...oh boy.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 02-05-2013, 05:05 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:86
topgun will become famous soon enough
They have replacement LEDs for both the standard and trailer mirrors. Been that way for about a year.
Double check to be sure before ordering that they fit your model year.
Regular mirror puddle lamps:
68067759AA - left
68067758AA - right
Tow mirror puddle lamps:
68087239AA - Left
68087238AA - Right
Tow mirror turn signals:
68087235AA - Left
68087234AA - Right
Non trailer mirror light replacement:
NOTE: The Light Emitting Diode (LED) units and printed circuit board for these lamps are serviced only as a unit with the lamp and lens assembly. If any part of these lamps is damaged or ineffective, the entire lamp assembly must be replaced.
1. Disconnect and isolate the battery negative cable.
2. Remove the mirror glass and case from the mirror housing (1).
3. Remove the three screws (2) that secure the front cover of the mirror to the mirror housing.
4. Locate the latch tab (4) on the lamp housing (3) within the lower, outboard side of the mirror housing.
5. Using a trim stick or another suitable wide flat-bladed tool, pry gently and evenly at the parting line on the outboard side of the mirror between the mirror housing (1) and the front cover to separate them far enough to disengage the lamp rear flange (5) from the lower rim of the mirror housing.
6. It may be necessary on some vehicles to gently pry between the forward flange of the lamp housing and the mirror front cover to release the strip of adhesive-backed foam weather seal (4) affixed to the forward flange of the lamp from the inside edge of the mirror front cover.
7. Reach inside the lamp housing and depress the latch on the lamp housing toward the vehicle to disengage and lower the lamp assembly from between the mirror housing and the front cover.
8. Pull the lamp assembly away from the mirror housing far enough to access and disconnect the mirror wire harness connector (3) from the lamp connector receptacle and remove the lamp
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Husky X-Act Contour Floor Mats, Cooper AT3 285/70/R17's, Moroso Catch Can
Old 02-25-2013, 04:44 PM
rewindgy rewindgy is offline
rewindgy is on a distinguished road
Yes, for the low low price of $51.05 for the Left side and 50.90 for the right side! I saw a liscense plate light @ Princess Auto for $8.00 - 3 led - 12 Volt - maybe I can Jury Rigg that into the Lense?
Old 02-28-2013, 04:44 PM
Arrowflinger09's Avatar
Arrowflinger09 Arrowflinger09 is offline
Vehicle: 2017 Ram 1500 Sport 4x4
Color: Blue Streak Pearlcoat
Rep:21
Arrowflinger09 is on a distinguished road
Originally Posted by topgun View Post
They have replacement LEDs for both the .
68067759AA - left
68067758AA - right
Everything I have seen is that these part numbers are for 2010-2012.. Is everyone else seeing this?
I have a 2009 with the driver side Puddle Lamp inop.. Anyone know if there are replacement lamps for the 2009?
Old 02-28-2013, 04:57 PM
SilverHemiRam SilverHemiRam is offline
Vehicle: 2009 Ram
SilverHemiRam is on a distinguished road
Yup. bought a replacement at the dealer for the pass. side of my 09. $107!!!
Old 03-01-2013, 11:55 AM
Rep:21
Wow.. Well, thanks..
Old 04-23-2014, 11:22 PM
padillavp padillavp is offline
Vehicle: 2012 Ram 1500
Color: mineral gray
Rep:19
padillavp is on a distinguished road
Cool
Thanks for the heads up i will check mine out.
