Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 02-02-2012, 12:42 AM
kawdog kawdog is offline
Vehicle: 98 Dodge Ram 1500 5.2L 5sp 4x4
kawdog is on a distinguished road
Default Trailer Wiring
Just bought my first Ram and I'm trying to get the trailer lights working. It had a round 7 pin connector with only 4 wires coming out of it. It was wired to a power converter box right behind rear bumper with a constant 12v from the battery but I was not getting power past the box. All of the factory plastic connectors for the tail lights were corroded and the pins broke when I pulled them apart so I spliced everything together
I now have a flat 4 pin connector spliced into the the tail lights, turn signals ect. I tested each wire with a test light to find the right ones. I can't get the right tail light or left turn signal working, everything else works. Does this truck need that power converter for everything to work? If not can you guys think of anything else I can try?
Thanks for your time!
Old 02-02-2012, 12:59 AM
Rep:2657
I don't know if it will work for you, but they make a 4 pin to 7 pin adapter
Old 02-02-2012, 10:10 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
4 pin connectors are usually for vehicles with integral turn signals and stop lights.
Brake and turn signal are the same light...not that they use separate bulbs like red for
stop and amber for turn.Yours should be controlled:
One wire controls the left brake and stop.
One wire controls the right brake and stop,
No you don't need the converter box. That's used if the turn and brake lights are separate. What you're describing is a setup someone had for a trailer with independent stop and turn signals. So whoever had the truck probably had a newer trailer.
Old 02-02-2012, 11:10 AM
I tried the 7 pin to 4 pin adapter, that didn't help. Sounds like maybe I have my wiring wrong. I've only wired 1 other truck and I was able to use the plug and play kit.
Right now I have white-ground, brown-left side tail light wire, yellow-left turn wire, green-right turn wire. Each wire lights the test light correctly.
What did I miss?
Thanks
Old 02-02-2012, 12:10 PM
Just wanted to add, the trailer lights work correctly on another vehicle. So I know I have something wrong, just not sure what.
Old 02-03-2012, 11:28 PM
Lots of views. Anyone else have any ideas?
