Old 02-02-2012, 11:07 AM
philpott50 philpott50 is offline
Vehicle: 2011 Dodge Ram
Color: Rugged Brown Pearl
Rep:49
philpott50 is on a distinguished road
Default Plastic rattle is driving me NUTS.
I have got a rattle up by my radio that just wont stop. Any ideas of what to make this stop. It just started about a week ago and I am about to go crazy.
Old 02-02-2012, 11:29 AM
mmullengs mmullengs is offline
Vehicle: 2014 Ram 1500
Color: Fire Red
mmullengs is on a distinguished road
Dam I thought that I was the only one having this issue since no one else said much about this issue. Mine appears to be making the rattling noise near the radio opening. Ill have to take to the dealer soon to get this rectified. I only have about 5,000 miles on the clock, you would not think with low miles you would have this issue.
Old 02-02-2012, 01:50 PM
Rep:49
I had the radio replaced by the dealer two weeks ago and ever since then it has rattled. I plan on taking it back to have them fix it. The only problem is I have to have time to do it.
Old 02-02-2012, 01:53 PM
CTYHNTR's Avatar
CTYHNTR CTYHNTR is offline
Rep:33
CTYHNTR is on a distinguished road
I have the same rattle I always bang on my dash in hopes it will go away, but Im probably only making it worse. Funny, I had a 6 year old Silverado that never rattled once, I have a 6 month old Ram that rattles like its going to shake itself apart at any minute.
2011 Dodge Ram Bright Silver Metallic - Magnaflow catback
2002 Camaro Z28 - some mods
Old 02-02-2012, 02:38 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
hmm I don't have a rattle there. I have noticed a minor rattle in my driver's door panel near the electric switches. If I push it towards the door it stops. My truck has almost 60,000 miles on it though.
Sean
Old 02-02-2012, 02:50 PM
Rep:49
CTYHNTR I had an 11 year old silverado for 4 years before getting the ram and samething not one rattle out of it. I have noticed that if I pull on the top were the the indention is it stops or if I push on the top corner of the radio it stops.
Old 02-02-2012, 05:42 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
just subscribing so i can follow.
Old 02-02-2012, 07:48 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
It sounds like the didnt bolt the bezel back down tight enough. I got lazy after my last radio install and didnt bolt it in all the way and when the subs hit and i have the volume down the whole thing rattles. Check to make sure everything is snugged up would be my first guess. I would take the bezel off myself and make sure the radio is bolted down tightly as well.
2011 Big Horn 4x4 -SnowWhite-
Old 02-06-2012, 02:59 PM
tjmjnj tjmjnj is offline
Vehicle: 2011 Ram 1500 4X4
tjmjnj is on a distinguished road
when I hit big bumps the drivers side dash (inside the dash) makes a god awful noise like something big is loose.
when I hit a series of small bumps while turning (sometimes not turning) by steering wheel bounces around and the front tires loose grip with the road
if I apply the brakes while hitting small potholes or road imperfects the ABS kicks in and the truck will not stop
truck just turned 15k and is 100% stock - 2011 1500 QC 4x4 4.7l - not to happy to say the least. Also, it appears to have a rod knock now. The truck has never been abused, never towed (doesn't have hitch) - I drive it 7 miles to work and back and a few weekend trips, that's it.
Old 02-06-2012, 04:46 PM
Rep:49
SS4Luck I think I might try your advise but how do I take the bezzell off? Does it just have snaps that pop off?
