Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 02-02-2012, 01:37 PM
bigj350 bigj350 is offline
Vehicle: 2001 Ram
bigj350 is on a distinguished road
Default Re usable trans. filter?
I went to napa for a transmission filter and they told me its probably a re-usable filter. Is that right? Thanks.
Old 02-02-2012, 02:08 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I'm not familiar with that trans, but it's probably serviceable. I was told a few years ago that the filter on my wife's aveo was not serviceable, and a few months ago I found that NAPA now carries it, so I did the service a few weekends ago. I think that they just play catch up with the parts as that trans was made by a foreign company. With your truck it should be serviceable, try searching online and at auto zone.
Worst case, if you can't find one to replace it, at least remove it when you do the service, and back flush it with fresh trans fluid, about a qt or 2 worth, to at least try to clean it out a little bit.
I'm sure someone else will know for sure and will chime in.
Sean
Old 02-02-2012, 02:16 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
if you are talking about the trans behind the 5.2 & 5.9 is is a replacement
Old 02-02-2012, 02:19 PM
snrusnak's Avatar
Rep:1388
Also, you are talking about an auto right? I'm not sure how knowledgeable you are on this but manual gearboxes almost never have filters.
Sean
Old 02-02-2012, 02:23 PM
Vehicle: 2001 Ram
Im going to take the transmission in for a flush tomorrow. If I do need to replace the filter I wanted to get one from napa since its cheaper than the what they have at the shop. Otherwise I'll just have a flush done if the filter is re-usable.
Old 02-02-2012, 02:25 PM
Vehicle: 2001 Ram
Ya, its an auto, I have the 46re. Ive just never heard of a re-usable trans filter before. Wanted know for sure whether I need a new one or not when I take it in tomorrow
Old 02-02-2012, 02:34 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
They are replacable, when you have it serviced have them tighten bands.
Old 02-02-2012, 02:43 PM
snrusnak's Avatar
Rep:1388
I've heard that flushes can damage the trans. I've heard if you do the flush, makes sure they use the trans pump to pump the fluid, not an external pump that they have, as it can dislodge material in the trans and from the filter and push it through the trans causing damage. Supposedly if you use the trans pump to flush it it will not harm anything.
Personally, I'm a fan of pan drop services where you drop the pan, replace the filter, gasket, and replace the lost fluid.
Sean
Old 02-02-2012, 02:44 PM
ramfam's Avatar
Trim Level: Base
Rep:21
The manual nv 3500,4500 don't have filter they are "sealed". (meaning that there's thead tape on the brass plugs so they don't seze to the aluminum trans)
Old 02-02-2012, 02:51 PM
Vehicle: 2001 Ram
Ive heard that about flushing too. I might just get the basic fluid and filter change. I'd change it myself but me and transmissions don't get along for some reason.
