Old 02-02-2012, 04:22 PM
bigred0603's Avatar
bigred0603 bigred0603 is offline
Vehicle: 2005 Dodge Ram 1500
Color: BLUE
Rep:38
bigred0603 is on a distinguished road
Default Foamy oil
Was changing my oil today and found foamy oil on the cap and in the fill I have. Even losing a little amount of antifreeze as well what should I check Ive read if u don't drive much it could happen as well and I don't drive much so please help and what could be the problem
Old 02-02-2012, 04:24 PM
bigred0603's Avatar
Color: BLUE
Rep:38
I've been losing very little anitfreeze is what I meant to say
Old 02-02-2012, 07:36 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Do you see where your antifreeze is going? If it is leaking somewhere and you can see it, breath a big sigh of relief. If not, it may be leaking from your headgasket. A quick checklist to run down:
- Is the oil on your dipstick milky looking as well?
- Can you smell the sweet scent of anti freeze from your exhaust pipe?
- Is your truck smoking excessively white from the exhaust?
- Can you see oil in your radiator?
Typically milky sludge crap on the underside of the oil cap is normal especially for a 4.7 liter. My concern is the reference to the coolant you are losing. On average I drive over 12-1500 miles a month on my 2002 and mostly longer trips where the engine temps are up enough to evaporate any condensate and I still get the small amount of "milkshake" under my oil cap.
Sure it'll suck, but it'll make you a man
Old 02-02-2012, 08:51 PM
bigred0603's Avatar
Color: BLUE
Rep:38
Ok my old oil looks fine nO milky look just black like old oil I'm gonna do a pressure test to see if we can see if there's a leak and where it's not much of a leak but wanna get it fixed asap
Old 02-03-2012, 01:05 AM
bigred0603's Avatar
Color: BLUE
Rep:38
If it's coming out my exhaust what does that mean
Old 02-03-2012, 09:07 AM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
It means the your head gasket is leaking it into your exhaust. Is that what you have going on? Any white smoke? You can still go ahead with the pressure test to be sure, in the meantime do a search in this forum for "head gasket" to get more info on replacement.
Old 02-03-2012, 11:25 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
As bigdaddy said, it's not uncommon for these trucks to develop a little milky goop around the oil fill neck because condensation collects there, especially on shorter trips where your engine might not reach full operating temp. I don't think it's an excessive problem but I have also seen quite a few peeps replacing leaking radiators on these trucks as well. Hopefully those two things are all you have going on. Keep us updated.
Old 02-03-2012, 01:18 PM
heminit heminit is offline
Vehicle: 2003 Ram SBRC
Trim Level: SLT Sport
heminit is on a distinguished road
A small coolant leak may indicate a heater core leak also. You should smell the coolant with the defrost on. There may also be a buildup on the windshield.
Old 02-03-2012, 01:39 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
Here is an old racers trick you may try.. disable the spark.. pull a plug you may have to do all 8 (1 at a time) place your finger over the hole and have someone turn over the engine.( what for the exhaust to force your finger off the hole), look at your finger tip of more important smell your finger tip if you see or smell anti freeze you have a gasket leak ( yea i know your have 16 plugs don't matter)
Old 02-03-2012, 01:56 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
i think it may also be related to the PCV valve...check/replace that as well...just my 2 cents...
