Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 02-03-2012, 03:57 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
To clarify my earlier post, if you are only seeing a small amount of water from your exhaust this is normal in the combustion process, it is a by product. A small amount of coolant going missing could be a simple leak, as mentioned earlier a heater core. Could you post a bit more specific on what exactly is coming out of your exhaust.
Sure it'll suck, but it'll make you a man
Old 02-03-2012, 04:25 PM
Rep:2705
almost clear water is suppose to come out of your tailpipe(s)
it is a function of the Catalytic Converter
Unspent gas fumes pass over the specially coated tiles inside of the converter & a chemical reaction takes place & it comes out of your exhaust looking like clear water
The compounds coating the inner structure of the cat literally strip, ram together, and otherwise muscle these emissions into less harmful gases and water, leaving the stuff that comes out of your tailpipe in much better shape.
http://autorepair.about.com/od/gloss...catalyti_3.htm
Old 02-03-2012, 04:48 PM
bigred0603's Avatar
bigred0603 bigred0603 is offline
Vehicle: 2005 Dodge Ram 1500
Color: BLUE
Rep:38
bigred0603 is on a distinguished road
I haven't noticed anything out of the exhaust just wondering what it meant if there was something
Old 02-03-2012, 07:02 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Good point on the PCV valve. That has nothing to do with losing coolant but it helps maintain proper ventilation and moisture control in your crankcase. If it's never been swapped or you don't know if it has, you should. It's cheap and easy....if you can find it on your engine, lol. Some folks seem to have a hard time tracking it down.
Old 02-03-2012, 11:06 PM
bigred0603's Avatar
Color: BLUE
Rep:38
Where is the PVC valve at
Old 02-04-2012, 12:45 AM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
Its on the side of the plastic oil filler neck, just below the oil cap.
