97 ram 4x4 shifting question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-02-2012, 05:29 PM
Drone dog Drone dog is offline
Vehicle: 1997 ram1500 sport
Drone dog is on a distinguished road
Default 97 ram 4x4 shifting question
my ram at times will start to go in and out of OD while driving down the highway. however, if i put it on cruise control, it stays in OD with no issues. in fact even if i take it back out of OD, it seems to work fine. Then a few days later, same thing happens. SInce putting it in cruise seems to fix the issue, i was wondering if this is a throttle sensor problem as opposed to a transmssion problem. ANy suggestions? if there is a throttle sensor some place, where is it and does anyone know how i can change it?
my tranny seems to work fine otherwise, the fluid level looks good and the fluid color is good. i just bought the truck about 6 months ago and have not done anything to it other than change the oil and sevrice the engine. i really do not know that the tranny has been serviced or when it was last. if it was doing this all the time, then i would assume it needed adjusting and the filters changed. but since putting it on cruise seems to help, i wondered about a throttle position sensor or something like that.
thanks for any help
Dog
Old 02-02-2012, 08:11 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Throttle position sensor, map sensor and speed sensor all control shifts, torque converter silonid lock up for over drive. Those tranmissions are all eletronic. So tps can have affect on od and could have a dead spot in it. And it is located on the side of throttle body on left side opposite throttle cable.
Old 02-02-2012, 09:53 PM
Thanks. Is there a way to test them? Expensive? Can I buy at auto zone and put on myself?
Old 02-02-2012, 11:25 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
News to me, I didn't think these trucks had MAP sensors, Thats interesting, I nee d to look into that, could be the cause of my 98's cold idle issues...
Old 02-03-2012, 12:26 PM
ramfam's Avatar
Trim Level: Base
Rep:21
If its not setting codes you might have to hook up a code scanner, do real time diagnostic or reoplicate problem as you drive to auto zone and use there's.
Old 02-03-2012, 12:31 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Yep there's a map, unfortunately seems all cars do. Just to piss us off and set codes when they completely fail.
