Old 02-21-2012, 08:38 AM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Should get an answer by this week. Cross your fingers
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 02-21-2012, 08:42 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I hope it fits, I'm ready to buy...
Sean
Old 02-28-2012, 05:11 PM
Chromedragon Chromedragon is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Power Wagon
Color: Fire Engine Red
Chromedragon is on a distinguished road
Ill be interested as well though i wont necessarily be buying right this min i just sorted out what air intake i can use in cali so im going after that along with a TB spacer and a tuner ....next will be exhaust but that seems like a good third along with an electric fan mod.
thanks for keeping after this.
Old 02-28-2012, 06:29 PM
snrusnak's Avatar
Rep:1385
I've been talking to Louie and I guess he got a response from ASP and there is a minor difference between the older and newer balancer, but the guy thinks it will still work fine. Won't know for sure until someone tries it though. I'm going to call him later this week and as long as there's no chance of any damage I'll buy the pulley and try it out.
Sean
Old 03-06-2012, 12:39 PM
snrusnak's Avatar
Rep:1385
I'm ordering it, will update whether or not it works within the upcoming weeks...
Sean
Old 03-06-2012, 06:49 PM
chambers chambers is offline
Vehicle: 2004 Dodge Ram 1500
Rep:29
chambers is on a distinguished road
I wouldn't risk it, there were problems w/ the original ASP pulley's which caused engine failures if I remember correctly. They were eventually resolved but I wouldn't want to be the guinea pig here. Another thing to note is the newer 4.7 has a different crankshaft and harmonic damper than the older one's. There is certainly a reason dodge changed them instead of reusing the crank and damper from the old motor. If they didn't design the pulley specifically for the new 4.7 then I wouldn't put it on it.
Old 03-06-2012, 08:41 PM
snrusnak's Avatar
Rep:1385
Now you're worrying me...
Sean
Old 03-06-2012, 09:24 PM
Rep:29
Just trying to give you all the info, I wouldn't put it on my truck. The gains aren't worth the risk of a messed up motor.
Old 03-06-2012, 09:29 PM
snrusnak's Avatar
Rep:1385
I understand and appreciate it.
He said the hub on it is 0.005" smaller diameter than the oem part, but he thinks it will still seal against the front main seal. He said other than that it looks the same. Not sure why dodge would change it by 0.005", doesn't seem like it'd even be something noticeable.
I want to do it, but now you got me worried. What problems did they have and was it with the 4.7L?
Anyone have experience with ASP or their quality/reputation?
Sean
Old 03-06-2012, 09:40 PM
Rep:29
Well I have the revised pulley on my 3.7, it's the same pulley as the one for the first generation 4.7. I haven't had any issues with it, quality, it's a pulley similar to the stock one, just underdrive to put less strain on the motor driving accessories which allows more power to the wheels.
The concern I have is what can happen if a harmonic damper/balancer/pulley is not right for the motor http://en.wikipedia.org/wiki/Harmonic_balancer. I don't know how many parts the old 4.7 shares w/ the newer one, but looking at the parts site the cranks and pulleys are different parts at different prices. That's why I'm raising the red flag here.
