Old 03-07-2012, 02:17 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Well I decided to stop my order for the moment....not sure what to do.
The guy says the dampeners (old style vs new) are identical except the hub diameter is 0.005" smaller on the new one. He thinks it will still seal to the front main oil seal. I don't really know what else would matter, it's not like they calculate a certain amount of weight for the balancer to go with a specific engine, right? It's just a hunk of weight....or am I wrong? I didn't think it was "designed" that in depth. I thought it was just "throw a hunk of weigh on that crankshaft...." type thing.
Obviously it has to be designed to fit properly and all that, but it looks like it does (as long as the oil seal still seals). But from a weight/balancer standpoint....I don't see how it could be an issue. I don't know much about this topic though...
Sean
Old 03-07-2012, 06:24 PM
chambers chambers is offline
Vehicle: 2004 Dodge Ram 1500
Rep:29
chambers is on a distinguished road
Well the early designs, I think on the hemi caused engine failures, the 4.7 was missing the keyway originally too which is also bad. I'm not sure if any failures resulted on the 4.7 one's. If the damper was applicable to the newer 4.7's I would think that they would have already been marketing them for some time now. Another company that makes them is ATI, they make higher quality one's, better balanced for higher rpm. Maybe shoot them an email or call since they also make one for the early 4.7's.
Take a picture of your crank pulley, I'll take a look at mine (the oem one) and see if they're the same or as close as ASP claims.
Old 03-07-2012, 06:58 PM
snrusnak's Avatar
Rep:1385
Ok I'll snap a picture maybe this weekend.
I decided to hold out and save another $175 for the ATI one. I'll get it sometime in the future. From what I can tell (not positive) the ASP one is a "dead weight" and the ATI one is a real balancer with a rubber insert, inertia ring, etc. So it will definitely do the job. I'm not chancing it on the ASP which appears to be a solid chunk of aluminum.
Maybe in a couple months I'll get the ATI.
Sean
Old 03-09-2012, 09:47 AM
snrusnak's Avatar
Rep:1385
I was finally able to get a hold of Nick at airram. I'm going to definitely hold out and try the ATI dampener instead of the ASP pulley. Probably (hopefully) in about a month or so (it is more $$$).
Nick offered me the same deal; I'll buy it and try it out, if it doesn't seal/fit then he will accept a return.
Sean
