Old 02-02-2013, 02:11 AM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
Default Power Liftgate problems
figured i would try this here since the Durango forumz are pretty slow.
I have a 2011 Durango Crew, we have had it for about a week now. Today I had a large box i loaded into the cargo area. it was a tight fit and when i closed the liftgate with the button in the cargo area it closed almost all the way and it hit the box and reversed. So I closed it manually and had to force it to latch.
Now it wont open using any of the power buttons, and when i do get it opened manually it will close with the button but wont latch all the way.
Is there some kind of reset procedure or known issues with the power liftgate?
Old 02-03-2013, 09:49 PM
Ramfd's Avatar
Rep:150
Well I finally figured it out on my own. I just pulled the 30a fuse for a few seconds and replaced it. That for what ever reason fixed the issue. Oh well. Not sure what or why it happened. But crisis averted.
Old 02-03-2013, 10:51 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Yes, you can pull the negative lead off the battery which will reset lots of system bugs. Same with the fuses.
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
