Old 02-08-2012, 07:25 PM
Bugaboo232's Avatar
Bugaboo232 Bugaboo232 is offline
Vehicle: 2011
Color: Deep Cherry Red
Bugaboo232 is on a distinguished road
Originally Posted by gingersport View Post
Do u think 5100's and the rcx body lift would clear 35-12.5?
Here is mine with 5100's and the rcx body lift, the tires are 295/65/20(35.5/12.2/20) on the stock rims. As you can see, there is plenty of clearance. Your only issue is going to be rubbing the UCA, which isn't a huge deal. I added .25" spacers to get rid of that issue, may not be enough with true 12.5" wide tires though.
gingersport
Did the body lift effect the distance between the exhaust tips and the bumper? Or do they move up with the lift? I've never paid attention to how the exhaust is mounted.
Relocating the tips with the rcx body lift is cake, just loosen the tips and they pivot up and look stock. 5 minute job tops... That wouldn't work with the 3" body lift though, that angle would be too much.
BLKSVT
more details on the BL install please! I had a guy tell me it was a PITA and he wants $500 to do it..
OP..That looks awesome man!
Do not pay more than $200 to get the rcx kit installed, it's very easy. The only power tool you really need is a Drill with a 1/2" bit. If you have a garage, basic tools, and some mechanical skills you should be fine. Read through the directions, if you see something that your not sure about let me know!
Old 02-08-2012, 08:37 PM
gingersport's Avatar
gingersport gingersport is offline
Vehicle: 2011 Dodge Ram
Trim Level: QC Sport 4x4
gingersport is on a distinguished road
Looks sharp! I had an exhaust shop put an 18"magnaflow with 2.5 pipes in and they welded everything together. I guess I can always take it back and have the tips moved.
Old 02-09-2012, 12:43 AM
KyleMc KyleMc is offline
Vehicle: 2010 Ram 1500
Rep:29
KyleMc is on a distinguished road
Originally Posted by Rug 15 View Post
what all did you order for this? (lift wise...) def looking for this as well. if you dont mind what you pay as well? thanks
Just the 2.5" RC leveling kit and 1/4" spacers. The lift is like $200 something, install was $280 including alignment after. The tires are what killed me, they were like $320 a pop. Altogether I paid around $2k.
Old 02-09-2012, 01:42 PM
BDG's Avatar
BDG BDG is offline
Vehicle: 2012 Ram 1500
Rep:68
BDG will become famous soon enough
Does anyone have tow hooks with a body lift? Do they need to be removed?
Exterior - Reflex Bedliner, Tow Hooks, AMP Power Steps
Performance - BT Catch Can, 18" MF Muffler + Y-Pipe
Tires - 35x12.50x20 Toyo Open Country MT
Wheels - Fuel Offroad Kranks 20x9, +1 Offset
Lift - Rough Country 4" Suspension Lift
