tonneaucovered.com
Old 02-03-2012, 02:01 AM
warlock warlock is offline
Vehicle: 1997 dodge ram
warlock is on a distinguished road
Default startup problem for dodge ram 1500
hellos
I have a big problem with my dodge, it veus boot.
I changed the spark plugs, the distributor and the distributor finger, the sensor pmh. It started 2 seconds and nothing.
could someone help me?
Undo edits
Old 02-03-2012, 03:11 PM
heminit heminit is offline
Vehicle: 2003 Ram SBRC
Trim Level: SLT Sport
heminit is on a distinguished road
Check the wiring on the distributor and make sure it's wired right. Was it running B4 you started working on it?
Old 02-03-2012, 03:56 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I don't know what scale you measure pressure with, but you should have 45 psi of fuel pressure,and rock steady under all conditions, its measured from the coupler on the fuel inject rail on top of the engine. I made my tester from a fix a flat tire sealant hose and coupler with a custom 'pin pusher ' for the schrader valve in the end of the hose, made from a pop rivet, and a gauge with an extension hose, so the gauge could be read from the drivers seat. Also, ignition coils fail without warning, about as often as a politician earning their pay, but it does happen. An electric fence tester is an easy to see shock free testing device for that, cost about the price of a six pack of beer at a harwar store that farmers go to.
Old 09-05-2012, 12:05 PM
I have buy a new sensor pmh because cables were summer lengthened, if he always starts not I will check the fuel pump
