Old 02-03-2012, 09:51 AM
Parkersdad Parkersdad is offline
Vehicle: 2013 Dodge Ram 2500
Color: Mineral
Rep:21
Parkersdad is on a distinguished road
Default Weird scenario please help
I have a 2011 Hemi. I Got something out of my truck the other day and then locked my doors with the electronic key. I started talking to my friend and he said look your bed light is on and your windows are going down in the front. I went to my truck and rolled the windows up and locked it again. In just a minute it happened again. I cut the truck all the way on and rolled the windows up and it fixed the problem. Has anyone ever heard of this before?
Old 02-03-2012, 11:35 AM
Rough 01 Rough 01 is offline
Vehicle: 2011 Ram 1500 Sport
Trim Level: Sport Quad Cab
Rep:67
Rough 01 will become famous soon enough
If you have remote start then there is a feature that if you press the unlock button on your remote 2x and hold it that the windows will roll down and doors unlock. That would explain the lights coming on and the windows coming down. The remote could've been pressed against something in your pocket or faulty electronics.... ????
If not that, then I blame gremlins and suggest not feeding your truck after midnight.
Old 02-03-2012, 03:40 PM
Color: Mineral
Rep:21
Thanks for the reply. I don't have remote start so maybe it was just a mess up in the computer. If it does it again I will call the dealer.
Old 02-03-2012, 04:52 PM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
the feature described above, is standard on the key fob, remote start has nothing to do with this.
Old 02-03-2012, 04:58 PM
Rep:67
My key fob remote did it when I had remote start on my 2010. I now have a 2011 w/o remote start and it doesn't work. I'm just going off of my experience.
Old 02-04-2012, 10:22 AM
Color: Mineral
Rep:21
Please elaborate. How do I make this happen?
Old 02-04-2012, 12:55 PM
nikeman nikeman is offline
Rep:91
You just hit the unlock button twice holding it down the second time until windows are down as far as you want them.
Old 02-04-2012, 03:52 PM
Rep:67
I would like to know if I'm on the only one who's truck doesn't do this. I do not have remote start and it doesn't work when I try it.
Old 02-04-2012, 04:14 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
Rough this is standard equipment that I found out about when I first got my truck I don't have remote start. it also depends on how your unlock is set on your EVIC if it is one push to unlock all or 2 push to unlock all that will make it either hold on 2 or 3 also this is not exclusive to 11s It also works on my father in laws 09 with remote start.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 02-04-2012, 07:35 PM
Rep:2705
You do Not need the remote start to make it work
you do need the FOB or FOBIK, also called the Frequency Operated Button Integrated Key
when you go into the Personal Settings on your EVIC, also called (Electronic Vehicle Information Center)
you can choose several different settings like
how many clicks it takes to unlock your doors, 1 click or 2
how many times the horn beeps when you lock your vehicle
Etc.
On my Ram, i push unlock once, just the drivers door unlocks
if i push twice, all the doors unlock
If on the 2nd push, don't let up on the button & your front windows start rolling down
only pushing the buttons in the door will bring them back up, safety issue, they want you to be close to the truck when you raise the windows, you don't want to pinch children's fingers, strangle your pooch, or choke your chicken, while closing the windows of course
I automatically let up a bit on the button when unlocking the doors, i almost have to concentrate to get the windows down with the remote buttons
My pants seem to do it more often by mistake. i have even started my Ram when squatting down to pick something up
