Old 02-03-2012, 02:31 PM
mugapug mugapug is offline
Vehicle: 2011 dodge 1500
mugapug is on a distinguished road
Default new wheels for the ram
I found a used set of Zinik Z70 20 inchers for a great price. My question is do I have to worry about backspace and offset or is it not that critical or is it as long as the bolt patteren is right I can use them?
Old 02-03-2012, 02:33 PM
Sorry its a 2011 spotsman packsge
Old 02-03-2012, 02:41 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
Do your mean Outdoorsman?? Tire clearence without the correct spacing will be an issue with 20"
Old 02-03-2012, 04:06 PM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
what he said plus if you haave a negative offset your tires will stick out from under the wheel wells. there could possibly be an issue with the inside of the wheel hitting the brake caliper too. if you can id test fit them before purchasing .
