Old 02-03-2012, 03:21 PM
shvtec95 shvtec95 is offline
Vehicle: 1995 dodge ram 1500
shvtec95 is on a distinguished road
Default my 95 1500 dodge ram with chk engine light on
The check engine on my 1500 ram comes on when the trans is shifted into drive...(never at an idle)...I ran a key dance ...an the code came back ....code 12 ....is there a solution to this code ?
Old 02-03-2012, 08:39 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Are you sure it was '12' ?? I'm not aware of that year/engine having that code.
brad
Interested in one of my mods?
Old 02-03-2012, 08:53 PM
Default my 95 ram..1500 with a 318
this was the result I got back after doing the key dance..
turn key on/off, on/off, on within 5 seconds and you should see the check engine light flashing.
flash pause flash, flash means code 12.
Old 02-03-2012, 09:07 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Was it followed by a 55?
Old 02-03-2012, 09:12 PM
well...on the next key dance i counted 21 flashes..
Old 02-03-2012, 09:18 PM
Vehicle: 95
Rep:1776
OxyO2 sensor does not detect rich or lean condition, or O2 sensor input voltage too high. DRB will indicate which side with dual sensors. The O2 sensor signal should fluctuate under normal conditions.gen sensor
Old 02-03-2012, 09:40 PM
and how do I tell which one ?
Old 02-04-2012, 06:54 PM
Vehicle: 95
Rep:1776
You're probably going to have to run a scanner/scan tool on it.
It'll tell you which one B1S1, B1S2, B2S1, B2S2.
