Old 02-03-2012, 08:13 PM
djeven djeven is offline
Vehicle: 2004 dodge ram
djeven is on a distinguished road
Default Camshaft Selection Help!!!
Got my engine halfway torn apart doing timing, water pump, airgap, new valve covers, etc and was thinking I should throw a cam in there while I am at it. So I got the 5.9 with supercharger, airgap intake, bigger throttle body, ignition, exhaust, tuner, bigger injectors. So any idea on what camshaft I should be putting in there? I have no idea what I am doing when it comes to selecting that sort of thing. I am looking for of course more power and torque but reading all those specs and lift duration or whatever just confuses me. So I use it for daily driving and occasionally towing stuff. An aggressive sounding one would also be nice to. Any advice is helpful as I would like to get one ordered so I can throw this beast back together and drive it again.
Old 02-06-2012, 04:03 AM
BIG HORNS BIG HORNS is offline
Rep:31
BIG HORNS is on a distinguished road
Hey there, sounds like a cool rig your putting together. I know what you mean with the cam specs, but I have the simplest and best advice, call the tech line at Comp Cams, these guys helped me through setting up 3 engines for drag cars over the last 20 years. These guys are no BS if you want the best. Call 1-800-999-0853 with your complete specs, including the following:
-Driveability required (daily driver?)
-Basic engine info incl horsepower/torque goals
-Valvetrain needs, you may have to upgrade the valve springs etc to go with cams
-Transmission and stall speed if auto
-If 4x4, size of tires/ gear ratio.
Good luck! Jim G
BIG HORNS: looking for a "14" best ET so far is 15.24 @ 91.89 showroom stock.
Old 02-10-2012, 06:48 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
I agree call the pros , you cant loose just gain
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
