Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-03-2012, 11:47 PM
mikelken mikelken is offline
Vehicle: 1999 Dodge Ram 2500
Color: Metallic Red
mikelken is on a distinguished road
Default No Refrigerant....will I hurt the compressor?
My ac condenser was punctured today, which caused the lose of all the refrigerant. If I drive like this (w/o turning on the ac), will I hurt the ac compressor?
Thanks in advance!
Old 02-03-2012, 11:58 PM
Color: Metallic Red
If I remember correctly, the ac will cycle even if the control is not in the ac or defrost position. Will it continue to do this without refrigerant? Will pulling the ac fuse solve the problem?
Old 02-04-2012, 05:41 AM
Nitro1 Nitro1 is offline
Vehicle: 96 dodge ram 3500. 4x4
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Nitro1 is on a distinguished road
Hey hows it going. same problem with me 96 ram. it kept cycleing .so u pull plug . every couple years ill throw a can of ac lube in there . not sure if i even need to to do that . but no problems yet. Been about 10 years now. Id love to hear from someone that knows AC
Old 02-04-2012, 06:54 AM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
dont quote me on this but i heard that there is a lubricant in the refridgerant that keeps the ac parts lubricated. not 100 percent sure though so hopefully someone else can chime in
Old 02-04-2012, 11:59 AM
Color: Metallic Red
Thanks Nitro1! I'll unplug the ac until I can get a new condenser and a recharge.
That's what i was afraid of. I'd rather not have to buy a new compressor, too.
Thanks daggertats!
Old 02-04-2012, 11:32 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
If your AC system is empty the compressor will not cycle. The system has a pressure switch, if the pressure is below a certain level it will not cycle the compressor.
