tonneaucovered.com
Old 02-04-2012, 06:42 AM
Nck's Avatar
Nck Nck is offline
Vehicle: 2013 Ram 1500 Laramie
Rep:74
Nck will become famous soon enough
Default I have an Emmisions question
So a while ago I put a flowmaster 44 on my 98, and now I want to put a magnaflow high flow cat to go along with the 44.
But will this still pass emissions, I live in Utah.
It will sound good with my k&n air filter.
Old 02-04-2012, 01:23 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
I don't see why not its not a california truck. Auto zone sells a cat that's two separate pipes in and a single out instead of welding the y pipes together, its a tick under 200.
Old 02-04-2012, 01:44 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
6.4L HEMI Driver
Vehicle: 2014 Ram 2500 CC 6.4L HEMI
Rep:86
ShiftJockey will become famous soon enough
As long as no codes are thrown and the PCM returns a "Ready" status to the DEQ machine, yer good to go.
I see no reason why this won't pass.
Michael
2014 BIG HORN CREW
6.4L HEMI
Old 02-05-2012, 07:10 AM
Nck's Avatar
Nck Nck is offline
Rep:74
Nice, thanks for the advice. I guess i'll go ahead and do it, I'd really love to find the single in dual out though, always wanted to dual pipes on her.
Old 02-05-2012, 10:29 AM
ramfam's Avatar
Trim Level: Base
Rep:21
They can be found.
Old 02-06-2012, 06:56 AM
Nck's Avatar
Nck Nck is offline
Rep:74
Originally Posted by ramfam View Post
They can be found.
But the question is, to put dual pipes on, wouldn't I have to buy new o2 censors, among a couple other stuff? Or if I just buy the dual out, do I not have to worry? Either way, I love loud trucks, not to loud that the neighbors call the cops, but just enough to satisfy. so that's kinda what I'm working for.
Old 02-06-2012, 01:34 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Well you might have to weld but you can find after market that have single in dule out but it would have to be welded in then there's the up and down stream sensor's. If you cut cat off stock y pipes the up stream will still work now for down. Mesure how far from cat it is. Drill a hole in new pipe slightly larger then sensor thereds grab a nut that sensor will thread into weld nut to pipe.
