Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 02-04-2012, 11:03 PM
crackerzach86 crackerzach86 is offline
Trim Level: SLT Big Horn
crackerzach86 is on a distinguished road
Default Sonnax problem
I installed my sonnax line booster yesterday and noticed a difference in the shifts. Today my check engine light came on, I plugged in my DSP and it said low transmission fluid pressure. I checked the fluid and it's good. I took the sonnax off and the check engine light is still on. Anyone else have this happen?
Old 02-04-2012, 11:38 PM
Rep:3337
Can't say I've had that issue. Did you check the level what it was warm? All the sonnax does is increase the line pressure to give you more pressure on the clutches, so unless you have a low fluid level due to the increased pressure or a faulty sensor, I don't know what it would be.
Old 02-05-2012, 12:43 AM
I checked the level when it was warm and it looked good. I checked it a couple hours later when it was cold and it looked good then too. Do you know where the pressure sensor is located? Its just weird to me that it says low pressure, I would understand a hi pressure alarm a little more.
Old 02-05-2012, 02:30 AM
DOZER's Avatar
DOZER DOZER is offline
Vehicle: 2009 Ram 2500 Quad cab 4x4
Color: Inferno Red
Rep:140
DOZER will become famous soon enoughDOZER will become famous soon enough
Send a message via Yahoo to DOZER
Check the cooler line filter. Mine threw a similar code and the filter was found to be clogged. Maybe the increased pressure stirred up something and it clogged the filter.
'06 2500 ST 4x4 Quad cab, Vararam CAI, Bed/Hood stripes, Vent visors, Bully tailgate lock, Moto Metal 909 18x9, Nitto Terra Grapplers 295/70/18 HBS 2" level, Bilstein 5100's, Bushwhacker flares, 5000K HID's, Diablo Trinity 87 tune, LineX, Bakflip F1.
Old 02-05-2012, 02:41 AM
xtremedurb00's Avatar
xtremedurb00 xtremedurb00 is offline
Vehicle: 2007 Dodge Ram 1500 QC BH
Rep:16
xtremedurb00 is on a distinguished road
Id check the filter first...I can see the sensor going bad but, not it its throwing a low fluid code.
20% Tint,Magnaflow Y-Pipe & Exhaust,Jet 180 TStat,NGK V-Power,TB Ground,EFan,Superchips 3865, K&N 57
Old 02-05-2012, 10:25 AM
Thanks, I will check this as soon as it gets light outside and let you know what I find.
Old 02-05-2012, 11:01 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
If all else fails try reloading ur tune. Not familar with DS but with SC it reflashes the pcm/tcm.
Old 02-05-2012, 01:41 PM
cmiller0711 cmiller0711 is offline
Vehicle: 2012
Trim Level: R/T
cmiller0711 is on a distinguished road
Reset your PCM and you will be good to go.
Old 02-05-2012, 02:15 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Yes reset the PCM and you should be fine. Unhook the negative battery cable for about 30 minutes.
I believe the way the sonnax works is that it is a resistor that alters the pressure sensor's signal to the pcm, making it appear lower than it actually is, and then as a result the PCM is supposed to add line pressure to compensate. The PCM thinks it's bringing the pressure back to normal, but since it's a false low pressure reading it ends up at a higher line pressure than it was before.
Supposedly this is a temporary effect. After some time the PCM (through other sensors, etc...) will recognize the actual line pressure, and will adjust the pressure back down to get back to stock actual line pressure.
Sean
Old 02-05-2012, 03:13 PM
Thanks guys, the filter looks good. I unhooked the battery for about an hour while I was getting ready to leave and I drove about 30 minutes to a buddies house for the Super Bowl and so far so good. It definately shifts harder, feels more like it should.
