Old 02-04-2012, 11:16 PM
fishinf1's Avatar
fishinf1 fishinf1 is offline
Vehicle: 2011 Ram
Trim Level: st
fishinf1 is on a distinguished road
Default controller fuse
Today we decided to hook up the old brake controller. We decided to hard wire the controller instead of waiting for the adapter (bad decision 1). Prior to the hook up we volt tested the wires on the factory plug in to determine the wiring. The Yellow with red tracer had 12.5 volts. Now the controller is hooked up we lost voltage. We unhooked all wires and still no voltage. I've looked through the fuse box and I'm lost here. Does anyone know where the fuse for the brake controller might be? I've checked almost every fuse in the box (pulling out 1 by 1). I know there are some areas in the box that state Tow. Do these areas need fuses added? Any help with this sure would help a feller out in a pinch. Need trailer brakes to get out of town.
Also, brake lights will not work with key off. work fine with key on. Is this normal?
Old 02-05-2012, 12:16 AM
ABCRUDE's Avatar
ABCRUDE ABCRUDE is offline
Vehicle: 2011 Ram
Trim Level: SPORT
Color: BLACK
ABCRUDE is on a distinguished road
the best i can figure out
the electric brake is JO2 30 AMP PINK IN FUSE BOX
HOPE THIS HELPS YOU OUT.
GOOD LUCK
BOB
LIFE HAS A TON OF CURVE BALLS
YOU JUST HAVE TO LEARN
HOW TO HIT THEM
Old 02-05-2012, 12:46 AM
fishinf1's Avatar
Vehicle: 2011 Ram
Trim Level: st
GOOD LUCK
BOB
THANKS A MILLION! I looked and looked and could not find a blown fuse. Flash light at the right angle and sure enough it was JO2. Where the heck do you find one of those funky 30 amp fuses?
Can anyone help with the wiring? From what we checked was as follows;
Yellow with tracer + hot
white with tracer brake light
Green ground
black brakes
Old 02-05-2012, 05:32 PM
fishinf1's Avatar
Vehicle: 2011 Ram
Trim Level: st
For future reference this is what I came up with;
truck trailer brake controller wires
1. Yellow with Red Tracer is power
2. White with Purple Tracer is Stoplight
3. Green is Trailer brakes
4. Black is Ground
fuse is J2 30 amp cost $4.59 a piece
This is for a 2011 Ram 1500 cc 4x4 5.7L
